Activity › Forums › Adobe After Effects › output module destinations
  • output module destinations
    Posted by Riccardo Sinti on March 26, 2010 at 3:26 pm
    I frequently switch between many projects during the day and each time Io render something AE remembers the last place i rendered to as default so I have to navigate to the project folder i want.
    Is there a way to tell AE to remember render folders on a per-project basis?
    Riccardo Sinti replied 16 years, 6 months ago 2 Members · 2 Replies
  • Erik Waluska
    March 26, 2010 at 3:58 pm
    Hi Riccardo, Unfortunately, I don’t know of any settings that will make AE remember the render location on a per-project basis. I also switch between multiple projects frequently so eventually I found a way to maintain my sanity by just creating on master folder called “RENDERS” that is the destination for all of my project renders. I keep it on the desktop but you could put it anywhere that make sense for you and your workflow. It works great for me, I almost never have to change the render path now.
    -E
  • Riccardo Sinti
    March 26, 2010 at 4:17 pm
    that wouldn’t work for me as I need to keep all my renders in separate folders per client, product job etc. and would have to then move the renders to their proper folders anyway.
    This should be an option!
    Thank You
