Activity Forums VEGAS Pro Output meter in Vegas 7 mixer will not oscillate
  • Output meter in Vegas 7 mixer will not oscillate
    Posted by Vance Bridges on November 15, 2008 at 4:27 pm
    Hey everyone. I finally joined the COW since I couldn’t stand
    you all having all the fun–. While many of you
    have moved on to newer versions of Vegas believe it or not
    I still enjoy Vegas 4 and 7–(4 allowing almost
    microscopic isolation and cutting of wavefile mistakes
    that 7 does not esp. critical in editing my narrations..
    and believe me I’ve tried to do that in 7 and can’t.)
    As to wavefiles and mixing on 7 here’s my problem: when
    watching the mixer window for a bus or the master–the
    output meter will naturally move up and down with each db
    change unless I put compression on or level all my peaks out–
    but this attribute has recently stopped (on both 4 & 7 as I
    cross ref files and finish on 7)… and I want it back.
    All it does now is hold at static peaks. I have checked
    and re-checked hold peaks and valleys, taken all compression
    or effects off and created virgin files to get the jumpy meter
    back– But it refuses. I need that function to control pin point
    levels in editing voice since I can manually control a peak
    where I want it with the volume envelope.I have a younger audio
    engineer associate who has all the bells and whistles at his
    studio to level my tracks for the final but I want to play
    with this myself…How can I get the jumping
    output meter back ?? Thanks/Vance.
    Vance Bridges replied 17 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
