Activity Forums Adobe After Effects output looks “soft”
  • output looks “soft”
    Posted by Kevin Ryan on September 25, 2008 at 12:24 pm
    I imported a dv filein AE CS3. The interlacing was bottom field first. I deinterlaced. I added some effects. Everything looked fine. I went to make movie. I set to render bottom field first. I put the rendered output on my edit system timeline,(Pinnacle Liquid Chrome), and the video looks softer than the origional. Any thoughts as to what I may be doing wrong?
    Kevin Ryan
    Videographer/Editor
    The Government Channel
    Charlotte, NC
    Kevin Ryan replied 17 years, 12 months ago 3 Members · 5 Replies
  • Mark
    September 25, 2008 at 2:56 pm
    I always found that when going back to Liquid (Blue). I found, for the cleanest renders, that the way to go is to go to an uncompressed AVI, or QT Animation and then let your Chrome do the re-render upon import. It sucks as it is more time consuming, but I found the results to be better.
    Best
    Mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • Kevin Ryan
    September 25, 2008 at 7:57 pm
    No, I believe I chose “off” for fields.
    I must admit I am confused about what I should pick.
    I thought I should choose off to to de-interlace the
    footage before working on it. Am I on the wrong track? Am I correct in assuming that as a matter of practice, its good to de-interlace, add effects, and then pick the origional field order when ready to render?
    Kevin Ryan
    Videographer/Editor
    Charlotte, NC
  • Grant Swanson
    September 25, 2008 at 8:05 pm
    When you’re working in AE you almost always want to work deinterlaced. So for you, you should have picked “lower-field first” in the interpretation dialogue.
    Grant Swanson
    Visual Effects Supervisor
    Video Apex – Minneapolis, MN
    videoapex.blogspot.com
  • Mark
    September 25, 2008 at 8:27 pm
    For Liquid files (and all video files) you definately want to intepret the fields correctly…DV based footage in NTSC land is lower, so in AE you will need to set to lower field first. When you render, you will also want to render out to lower field first if you are going to TV, or non-interlaced if you are going to a computer screen.
    I would still render out to an uncompressed and let Liquid re-render….as mentionned previously I had better results using this method.
    Mark
    Mark Harvey
    Senior Editor
  • Kevin Ryan
    September 25, 2008 at 10:37 pm
    Thank you all for the responses. This information
    will help a great deal.
    Kevin Ryan
    Videographer/Editor
    Charlotte, NC
