Activity Forums Panasonic Cameras Output live DV-NTSC w/ timecode while recording on AJ-1200a
  • Output live DV-NTSC w/ timecode while recording on AJ-1200a
    Posted by John Chater on August 28, 2005 at 1:01 am
    Is it possible to output a DV-NTSC over Firewire with matching timecode while simultaneously recording ‘live’ on location to AJ-1200a deck at 720/60P from Varicam?
    I am feeding a AJ-1200a deck with a HDSDI signal from the Varicam. I need to create a matching timecode DV dub to either FCP or a Mini DV deck. Timecode is RecRun set on deck.
    I have been able to do this with picture and audio, but unable to get timecode. Thoughts?
    John Chater
    Tony replied 20 years, 12 months ago 2 Members · 1 Reply
  • Tony
    August 31, 2005 at 5:30 pm
    John,
    The 1200A had menus regarding the embedded tc within the HDSDI signal.
    Did you check these menus?
    Also check the 800 series menus which affect the firewire output.
    Tony Salgado
