Activity › Forums › Adobe Premiere Pro › Output is milky
Output is milky
Posted by Dave Rogers on December 7, 2011 at 5:32 pmI have edited my footage and color corrected it, it looks fine in Premiere but on output it looks milky and desaturated when viewed with VLC. I have tried various output formats and they all have the same milky look. BUT if I import the outputted files back into Premiere they look like my original footage within premiere i.e. saturated and contrast is ok.
Any Ideas why they look so bad in VLC
Kevin Monahan replied 14 years, 9 months ago 5 Members · 9 Replies -
Petros Kolyvas
December 7, 2011 at 6:03 pmI think it depends which output module VLC is using for playback. Can you check? Try switching between the options to see if you can’t get it to match. It’s highly likely there’s nothing wrong with your video at all.
There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger -
Gleb Rysanov
December 7, 2011 at 7:01 pmDave, you may also want to make sure that the output levels of your video are set to 0-255 and not to 16-235 (the so called ‘Broadcast Safe’).
Dave Rogers
December 7, 2011 at 7:20 pmThanks for the reply, excuse the noob question but how do I check the output levels are at 0-255 rather than 16-235
Dave Rogers
December 7, 2011 at 7:31 pmI was on the default output module
I stepped through all the output modules as suggested but unfortunately they don’t show any improvement.
Kevin Monahan
December 7, 2011 at 8:02 pmCheck out this article: https://sekharpadikkal.wordpress.com/2010/03/26/fix-washed-out-colors-or-black-levels-in-vlc-player/
Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
Ann Bens
December 7, 2011 at 11:52 pmWhat is your source, what are your sequence settings and what are your export settings. Be specific please.
Adobe Certified Expert Premiere Pro
Adobe Community Professional -
Dave Rogers
December 8, 2011 at 9:20 amBrilliant that fixed it, thank you to all that offered assistance
Dave Rogers
December 8, 2011 at 9:22 amI should have added it was the VLC link posted above that worked for me
thanks again to you all -
Kevin Monahan
December 8, 2011 at 10:21 pmYou’re welcome. Glad that worked for you.
Kevin Monahan
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
