Activity › Forums › Blackmagic Design › Output from ultibridge Extrmee DVI to Dell Monitor from After Effects frozen
  • Output from ultibridge Extrmee DVI to Dell Monitor from After Effects frozen
    Posted by Deleted User on July 20, 2007 at 10:50 pm
    Hello,
    I am using Blackmagic Multibridge Extreme and the DVI out of the Multibridge to a Dell 24″ LCD screen. In Adobe After Effects I am working with a 1280×720 25 project in the Blackmagic video preview settings in After Effects I selected 1280×720 60 as if I use 50 I get a pink garbled screen on my display to the DELL monitor from the Multibridge. 60hz video preivew seems to work fine.
    I am doing the ram preview and scrubing the after effects timeline, I have show interactions etc in the video settings. I start to see my work area on the screen then all of the sudden the DELL gets a frozen display of the after efects project which is outputting. Even though my screen on the pc I am using to design on works perfectly. I am using After Effects 7 pro with upgrade on Windows XP with Blackmagic Multibridge 6.1.2 software.
    Do anyone have any ideas so I can get the previews back to the Dell?
    Leo
    Deleted User replied 19 years, 2 months ago 2 Members · 2 Replies
  • Kristian Lam
    July 27, 2007 at 7:58 am
    Hi Leo,
    [Leo Baker] “…I am working with a 1280×720 25 project in the Blackmagic video preview settings in After Effects I selected 1280×720 60 as if I use 50 I get a pink garbled screen on my display to the DELL monitor from the Multibridge.”
    This is probably because 720p50 does not work on the Dell display.
    Sounds like you’re trying to send a 720p50 signal out via the 720p60 component which is why you’re having issues.
    regards
    Kristian Lam
    Blackmagic Design
  • Deleted User
    July 27, 2007 at 9:38 pm
    Hello,
    I shot on the JVC HD100U in 720p mode 25/50, if I go into After Effects and create a new composition using the presets HDTV 720p/25.
    I get a garbled view if I go to the Blackmagic under the video preivew settings and have it set to the 50 out as I get a garbled pink screen onto the DELL moinitor via the DVI out on the Multibridge Extreme to the DELL unit.
    Is they anyway i can work correctly on the Dell? As it seems to like the 60hz out.
    Leo
