Activity › Forums › Apple Final Cut Pro Legacy › Output from timeline to dvd drive.
Posted by Sabrina Ramdass on September 17, 2011 at 2:56 amHi using final cut pro 4 I have some footages in the timeline which I would like to output to the DVD drive.
Please drop me a line if this is possible.
ThanksAndrew Rendell replied 14 years, 11 months ago 4 Members · 4 Replies -
Rafael Amador
September 17, 2011 at 8:23 amHi Sabrina,
Yes, Is possible, but you need a DVD recorder able to record in real time.
Google “DVD real time recorder”.
rafael -
Chris Tompkins
September 18, 2011 at 3:26 pmEither you have an I/O card where you can play the sequence out in realtime to an ext. DVD recorder OR you export your sequence “Current Settings” to a file and compress that to DVD files and create/burn a DVD on your comp.
Chris Tompkins
Video Atlanta LLC -
Rafael Amador
September 18, 2011 at 4:25 pm[Chris Tompkins] “Either you have an I/O card where you can play the sequence out in realtime to an ext. DVD recorder “
Most accepts FW.
rafael -
Andrew Rendell
September 19, 2011 at 8:20 amI usually just export the sequence onto my desktop and use the “OneStep DVD from movie…” option in iDVD to make a DVD.
