Activity Forums Maxon Cinema 4D Output Framerate
  • Output Framerate
    Posted by Aaron Martinez on December 8, 2007 at 1:33 pm
    Hell, i am using cinema 4d 10 and i have a question about the framerate setting…In the output section of the Render setting window i set my faramerate to 25, but oddly when i set the frame i would like to render i must offset the frames for whatever reason…for example if id like the render t o start on frame 50 on my time line i must set the first frame to 80…and if i would like to end on frame 100 i must set the last frame to 144…i have no explanation for this strange offset and could only wonder if there s another framerate option that i must have set to say 30 frames per second and this causes my render offset…anyone with an idea what i hav done wrong…
    thanks
    Aaron Martinez replied 18 years, 9 months ago 2 Members · 2 Replies
  • Samir Kharchi
    December 8, 2007 at 1:48 pm
    click CTRL+D to get the scene settings. In there you must set the FPS for the scene! That
  • Aaron Martinez
    December 8, 2007 at 5:00 pm
    thanks a million is was that easy!… i have another couple of problems that maybe you could solve for me…
    1. for whatever reason my text object doesnot appear in the render…i need to start the render on the frame the text appears for it to showup in the render…for example i i have a text that scales up from 0 to 100 starting on frame 10 and ending on frame 20…if i start the render(tiff sequence) on frame 1 the text object is not there. if i start on frame 10 it is there…
    2. i wanted to render the project with objects motion blur and scene motion blur…i set a couple of motion blur tags on the objects that need the motion blur and in the render settings effects i set post effects for object motion blur and scene motion blur…i then set to render a tiff seq…and the computer shows to be doing the work but it doesnt create any images in the target file…when i turn off the post effects object and scene moton blur it renders the images…
    any idea what im doing wrong…
    thanks…
