Activity › Forums › Zaxwerks › Output for high definition
  • Jon Okerstrom
    November 20, 2007 at 1:44 am
    Hi Jose,
    It’s certainly possible to render ProAnimator movies in high-def.
    Does your projector output 720p or 1080p or 1080i formats? Knowing that – as well as your playback device and medium will give you the answers you need.
    Without knowing that, my assumpion is you’ll want ot render your movies at 720p, which requires 1280×720 pixel resolution, non-interlaced.
    1920×1080 is another common format which results in much larger files, but it may be overkill depending on your output device. 1080p or 1080i are both doable, assuming you have a playback device.
    For more on HD formats, follow the link below:
    https://www.adobe.com/designcenter/productionstudio/articles/prs1ip_hdprimer/prs1ip_hdprimer.pdf
    Hope this helps.
    Jon
