Activity Forums DaVinci Resolve output fields when paused oddities
  • output fields when paused oddities
    Posted by Michael Cinquin on January 6, 2011 at 5:06 pm
    Hi
    in Resolve 7.1, the “output fields when paused” setting works opposite to the way I would expect.
    When it’s not checked, Resolve outputs only 1 field.
    When it’s checked, Resolve outputs both fields.
    I’m using HD 1080i50 as a video monitoring format.
    The problem is fairly easy to diagnose : take an interlaced shot with lots of motion and look at it on a CRT monitor (it should jitter when outputting both fields), or take a progressive shot with very thin diagonal lines and look at it on a projector (the diagonal lines should not have staircases when outputting both fields). This cat’s moustache would do the trick.
    Can anybody confirm Resolve behave the same for them ?
    Michael Cinquin
    Final Cut Pro – Avid Media Composer editor
    DaVinci – Color – Baselight colorist
    http://www.michaelcinquin.com/tools : tools for FCP | Color | RED | subtitles | Cinema Tools | Timecode – Keycode calculator
    Sascha Haber replied 15 years, 8 months ago 4 Members · 4 Replies
  • Holger Hessinger
    January 6, 2011 at 7:29 pm
    I WOULD expect Resolve to output both fields when
    “output fields when paused” is checked!
    Sounds logically to me
    Holger
  • Michael Cinquin
    January 6, 2011 at 7:34 pm
    [Holger Hessinger] “Sounds logically to me”
    Of course my bad, I described badly the problem and reversed Resolve’s reverse behavior.
    Here is the correct description :
    When “output fields when paused” is not checked, Resolve outputs both fields.
    When “output fields when paused” is checked, Resolve outputs only 1 field
    Michael Cinquin
  • Joseph Owens
    January 6, 2011 at 10:53 pm
    Sounds like semantics to me.
    “Output fields” I would expect one field at a time, but not necessarily plural. If unchecked, I’d expect “Frames”, which of course if interlaced are plural fields.
    Its a little different than the Kona menu protocol which might just be better English.
    jPo
    You mean “Old Ben”? Ben Kenobi?
  • Sascha Haber
    January 7, 2011 at 7:31 am
    I second this, it’s upside down.
    Output fields should display both, normal pause should truncate or interpolate one and output a steady image.
    A slice of color…
    DaVinci 7.0.3 OSX 10.6.5
    Dual Xeon 2,4 RAM 6 GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
