Activity Forums Adobe Premiere Pro Output Codec Advice Needed
  • Output Codec Advice Needed
    Posted by John Taylor on September 1, 2014 at 4:37 pm
    Good morning and happy labor day weekend to all. Yep I’m working!
    I have large files (2G to 5G) from talking head studio/white background interviews shot on a Canon 70D at full 1080P, low compression which creates an H264 .mov file.
    I am tweaking (levels, sharpness, combining over 4G files) a few scenes in PP Windows CS6 and need to export to a file, maintaining image quality to send to an edit house using final cut.
    What codec(s) wrapper(s) do you suggest?
    I have tried H264/QT and it seems to look a little fuzzy/grainy and the file size is smaller.
    Thanks in advance,
    John
    John Taylor replied 12 years ago 2 Members · 2 Replies
  • Ivan Myles
    September 1, 2014 at 6:06 pm
    On Windows consider using AVC-Intra or installing Cineform GoPro. Uncompressed is another option (V210, DPX, QuickTime YUV) but it will create very large files.
  • John Taylor
    September 5, 2014 at 12:38 pm
    Ivan,
    Thanks for the suggestions.
    I ended up using DNxHD and it looked fine with a bit larger file size.
    John
