Activity › Forums › Avid Media Composer › Output Anamorphic to HD CAM
  • Output Anamorphic to HD CAM
    Posted by Shawn Rosenblatt on October 3, 2011 at 7:21 pm
    Hello,
    I have a QT file that is native 1280×720 anamorphic & I need to lay it to tape. It needs to be output to an HDCam tape from an avid.
    I’m not sure if I need to apply any avid effects like “reformat”, or if I need to change the setting on the deck to letterbox.
    Like I said, they want me to output it 1280×720 anamorphic. Can I even do that to my deck? It is a Sony HDCAM (HDW-M2000) that only seems to have options for 1080.
    John Pale replied 14 years, 12 months ago 2 Members · 1 Reply
  • John Pale
    October 4, 2011 at 1:49 am
    HDCAM is only 1080 (1920 x 1080)
    If you import it in a 1080 project and place it in a sequence your Avid will upscale it to fill the frame and you can output to HDCAM.
    If you want to output to a 720p master, you need DVCPRO HD, D5 or HDCAM SR.
