Activity › Forums › Boris FX Particle Illusion › output always 720*480 ingnore settings ?
  • Hunter Hempen
    April 25, 2010 at 11:20 pm
    ive noticed the same problem, really bugs me, any answers?
  • Alan Lorence
    April 26, 2010 at 2:17 pm
    What output format are you choosing? If you’re choosing an image sequence (PNG for instance) than it should work fine. If you’re creating an AVI or WMV, some codecs will only output at specific resolutions — for example, the DV codec may only work with 720 x 480.
    So try changing your codec. I suggest Lagarith or HuffYUV, or DivX.
    Alan.
    http://www.wondertouch.com
