Activity › Forums › DaVinci Resolve › Output 5K Footage from Resolve Lite?
  • Output 5K Footage from Resolve Lite?
    Posted by Daniel Elkayam on May 13, 2014 at 8:29 pm
    Hello! I am working with 5K Red Epic footage and coloring in Da Vinci Resolve Lite. I want to export the final graded footage as ProRes 4444 in the original 5K resolution (4800×2700). However, in the Output Settings, it only lets me select up to 4K UHD resolution (3840×2160). Even if I go to Custom Size, it won’t let me enter a resolution larger than 3840×2160.
    Is this a limitation in Resolve Lite? Or with Resolve in general? I can’t seem to find anything online or in the manual saying that this is a limitation and I’ve seen other people refer to exporting footage at 5K. I’m wondering if there’s a setting I’m missing and if it is possible to export at 5K (4800×2700) resolution from Resolve Lite.
    Please let me know! Thanks for any help!
    Marc Wielage replied 12 years, 4 months ago 3 Members · 3 Replies
  • Eric Johnson
    May 13, 2014 at 9:16 pm
    You need full Resolve.
    eric b johnson
    online editor | colorist | workflow
    https://vimeo.com/ebjohnson/colorreel
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Daniel Elkayam
    May 13, 2014 at 9:29 pm
    Ok, thought that might be the case. Thanks!
  • Marc Wielage
    May 14, 2014 at 5:56 am
    Spend the money on the full version. It’s worth it.
