  • Posted by Dave Lasdon on January 12, 2012 at 12:34 am
    I’m using FCP 7. If I output as a Quicktime movie my dimensions are fine. But that produces files too big to upload to Youtube and I need the producer to see the work. Yet when I output using Quicktime conversion I can’t seem to find the correct dimensions. I’ve tried several different ones and while they each do it a little differently they’re all producing a movie that’s smushed. It’s either not wide enough or too high. Is there a specific dimension I should be using? The film is 960×720 in my sequence settings and that’s not an output option.
    Ben Holmes replied 14 years, 8 months ago 3 Members · 3 Replies
  • David Roth weiss
    January 12, 2012 at 12:39 am
    You really should be using Compressor for this, but if you are intent on using Quicktime Conversion and you don’t want to create a squeezed file, your output needs to forced to 1280×720 with square pixels
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
    https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Dave Lasdon
    January 12, 2012 at 1:34 am
    Thanks. I’ve never used Compressor, but it sounds like what I’d want to produce smaller files.
  • Ben Holmes
    January 12, 2012 at 3:03 pm
    I have one simple rule when doing this for approval – output as Apple TV using QT conversion in FCP. It’s hellishly quick, produces 720p video at a good file size (around 25-30Mb/minute) and the results look good in Youtube and Vimeo (as well as importing quickly to those services).
    You might want to change the file extension afterwards from m4v to mov if you’re sending them to a client. The m4v extension tells a computer to import it to iTunes.
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/community/communitydetails/?UserStoryId=8757
