Activity › Forums › Adobe Illustrator › Outlines of warped text for vinyl cutting?
  • Outlines of warped text for vinyl cutting?
    Posted by Pat Hindman on March 23, 2010 at 5:09 pm
    Hello,
    I’m not super-experienced in Illustrator but I can usually get around and get done what I need to do. I am trying to help a friend with graphics needs for a startup vinyl cutting business. As many of you know, vinyl cutting is all about outlines (which I’m having to learn the hard way).
    I’m trying to recreate a logo that has arched text. I’ve arched the text and matched it perfectly in using the Warp/Arch effect. However, when I view it in Outlines view, the text still looks normal (non-arched) even before or after converting to outlines?!?
    Should I be concerned about this? My friend has always asked me to view what I do in outlines to minimize overlapping paths, etc etc. I want to make sure his vinyl cutter cuts the “arched” lines and not how it’s looks when viewed in Outline mode.
    Thanks very much!
    Gabriel Luke replied 6 years ago 4 Members · 4 Replies
  • Les Nemeth
    March 24, 2010 at 6:31 am
    Select the arched logo, then Object > Expand Appearance.
  • Pat Hindman
    March 24, 2010 at 1:58 pm
    Perfect! Thanks Les!! That did the trick! I love this forum!!!
    Thanks again!
    Pat
  • Arnaldo Riquelme
    June 13, 2020 at 6:34 pm
    thanks! 10yrs later but work for me too
  • Gabriel Luke
    September 22, 2020 at 1:25 am
    The drop shadow in inkscape, like most vector applications I know of, is a raster effect or a bitmap when it has a drop shadow. All paths are required for the vinyl cutter, so it can not operate with a bitmap. A drop shadow is also a raster effect as it gives it a natural look as it is blurry around the edges. Fuzzy, which is all straight line, does not fit well as cut vinyl. If you want a solid block or shape, just draw it as a shadow. Alternatively, you can work with a replica of the main form and distort it such that it is inverted and / or upside down or angled to whatever scale you want a shadow to imitate. Only catch the edge of the copy and begin to drag it.
