Activity Forums Maxon Cinema 4D Outlines in cel renderer
  • Outlines in cel renderer
    Posted by Manny Rellesiva on May 19, 2014 at 8:52 am
    I want to render just the edges of an object without including the polygons lines inside. If cel renderer is activated, it also renders the polygons inside. How do I get rid of the polygon lines? What options should i tick or activate so that only edges of the shape are rendered. Should I use Sketch and toons?
    here is the sample images i want to accomplish:
    https://www.youtube.com/watch?v=_wqm6G5DjaI
    drag at 13:40.This is the sample render i want to achieve.
    I have a bus, taxi and stadium model. If i use cel renderer, it also includes all the polygon lines inside a shape, I only want to render the edges of the shape without the inside polygon lines so that it looks clean and easily seen as the object.
    manny
    Brian Jones replied 12 years, 4 months ago 2 Members · 1 Reply
  • Brian Jones
    May 21, 2014 at 2:12 am
    can’t do that with Cel renderer you need S&T
