Activity Forums Adobe After Effects Outline text with image filling text
  • Outline text with image filling text
    Posted by Jake Diamond on August 29, 2013 at 11:51 am
    I am filling a text layer with video below it on the timeline. I have the video layer track matte selected as ‘alpha’, showing the video through the text. I’m trying to put an outline around the text to make it stand out. I imagine it’s very simple, and I’ve tried all sorts of things and can’t get it to work.
    Any help is greatly appreciated!
    Thank you,
    Jake
    Jake Diamond replied 13 years ago 2 Members · 2 Replies
  • John Cuevas
    August 29, 2013 at 1:20 pm
    If it’s only a few words or times you need to do this, I’d just duplicate the text layer and switch the fill off and turn the stroke on.
    If it’s going to be a lot of text layers, I would probably come up with a precomp-text scheme, so that I only have to change one layer in the precomp and have it ripple into my final comps.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Jake Diamond
    August 29, 2013 at 2:16 pm
    John,
    Duplicating the text and turning the stroke on worked. Problem solved.
    Thank you!
    Jake
