Activity Forums Adobe Photoshop Outer Glow Problems!
  • Outer Glow Problems!
    Posted by Simon Harris on January 10, 2012 at 1:26 pm
    Hey guys. Hope you can help me with this one…
    I have an image that has an outer glow applied to it. Whenever I come to rasterize the image layer the glow suddenly darkens. This has been happening for a few weeks and I cant figure out how to fix it. I may have accidentally pressed the wrong shortcut without knowing but I don’t know what could make this happen.
    HELP!
    Stanley Parrish jr replied 14 years, 8 months ago 2 Members · 1 Reply
  • Stanley Parrish jr
    January 10, 2012 at 5:06 pm
    You shouldn’t have to rasterize the layer as it should already be rasterized. Check to see if you’re in rgb mode and not cmyk mode.
    If you want to flattened the glow layer, you can try putting an empty layer under it. Click the glow layer, hit ctrl(command) + E, and that will merge the two layers.
    Stanley Parrish
    http://www.stanleyparrish.com
