Activity › Forums › Apple Final Cut Pro Legacy › Out to DVD studio
Out to DVD studio
Posted by Mark Dannunzio on May 4, 2006 at 3:51 pmhello,
I marked where I want my chapters in FCP.
I exported using compressor.
It seems like DVD studio Pro does not recognize my chapter marks from compressor.
Doing something wrong?? Hope this makes sense. Thanks alot.
-MarkNicholas Bierzonski replied 20 years, 4 months ago 6 Members · 5 Replies -
Luke David
May 4, 2006 at 4:06 pmI have had the same issue and I don’t think DVDSP sees chapter markers in compressor, but if you do a straight QT export (no conversion) and leave the encoding to DVDSP, it does work. good luck
Paul Nevison
May 4, 2006 at 4:18 pmyou can always add your chapter markers in the timeline in dvdsp – thats what i ended up doing with my last project and it worked fine.
G5 DP 2.0
4.0G RAM
OS 10.4.6
QT 7.0.4
FCP 5.0.4
BMD Decklink Extreme 5.5.1
PAL Land -
Chris Babbitt
May 4, 2006 at 5:23 pmChapter Markers work fine when encoding with Compressor. Just make sure when exporting your Quicktime Movie from FCP, that you select “DVD Studio Pro Markers.”
John Pale
May 4, 2006 at 5:33 pm[Chris Babbitt] ”
Chapter Markers work fine when encoding with Compressor. Just make sure when exporting your Quicktime Movie from FCP, that you select “DVD Studio Pro Markers.””
Correct. I do it all the time and it works fine. Also, make sure you have actually made chapter markers…you need to click the chapter button when the marker window opens…regular markers are NOT chapter markers.
Nicholas Bierzonski
May 4, 2006 at 5:44 pmThere could be one or two answers to this question. When you add your marker in FCP hit “mm” This will open the marker window. Name your chapter. and click “Add Chapter Marker”. If you don’t do this I don’t think DVD pro reads this as a true chapter marker. Many people use Markers for editing, soundtracks etc etc etc…
Secondly in Compressor check your extras tab and make sure your mpeg 2 setting is enabled that says “Include Chapter Markers Only”. This hopefully should solve your issue. Let me know how you make out. If you don’t use markers in FCP besides Chapter markers you can leave “Include Chapter Markers Only” unchecked. Let me know how you make out.
-Nicholas Bierzonski
Editor/DVD Author/Java Boy
http://www.finalfocusvideo.com
