Activity Forums Adobe Premiere Pro Out of Sync Video
  • Out of Sync Video
    Posted by Jerry Black on July 21, 2007 at 2:21 am
    I recelntly attempted to import some captured video from an older Sony analog camera that was capture a year to ago. What was strange is that the video was bent over and stretched and appeared like the picture on older TV sets when the horizontal hold (frequency) was mis-adjusted. I have never seen this before and was wondering if there is a setting in Premier to correct. The audio is normal.
    This appears in the monitor if I put it there or in the clip preview window. Natually, moving it to the time line results in the same results.
    Suggestions, comments or advice??
    Tim Kolb replied 19 years, 2 months ago 4 Members · 6 Replies
  • Blast1
    July 21, 2007 at 5:19 am
    Sounds like the a bad capture
  • Mike Velte
    July 21, 2007 at 1:43 pm
    Often consumer camcorders cannot playback video shot on another camcorder correctly…tracking error.
  • Jerry Black
    July 21, 2007 at 3:00 pm
    The caputed avi video plays fine when playing it on Microsoft Media Player, and since I am not attempting to play the original tape, but the captured video, it would seem that the issue is not one of playing an older analog clip on a new camcorder–it am in the Premier remember, and it can’t be a bad capture if I can play it with Media Player. This is a strictly a Premier issue. It opens and palys on the time line in Vegas as well.
    Would appreciate additional input as to the Premier issue.
  • Blast1
    July 21, 2007 at 9:33 pm
    What you are describing is usually a analog problem, a corrupted MainConcept dv codec can cause problems, you can write to support at MainConcept and ask for another dll, you have to tell them what version of Ppro you are using, you should also include this information when asking about a problem on a forum
  • Jerry Black
    July 22, 2007 at 2:20 am
    The file is an AVI file not MPGE2. Not sure I understand what the decoder would have to do with since I am not attempting to decode or render it to an MPEG at this point.
    I simply do not see the relationship, but thanks for the input.
  • Tim Kolb
    July 22, 2007 at 2:11 pm
    [jkb242] “The file is an AVI file not MPGE2. Not sure I understand what the decoder would have to do with since I am not attempting to decode or render it to an MPEG at this point.”
    Main Concept makes the DV codec inside PPro.
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
