Activity Forums Apple Final Cut Pro Legacy out of sync nested sequence (tif animation)
  • out of sync nested sequence (tif animation)
    Posted by Tali Clarke on August 31, 2010 at 8:05 pm
    Hello!
    I’m having a problem with a nested sequence and couldn’t fid any solutions online.
    I have a sequence of TIFs that I made an animation with, it is going into a larger sequence of Apple ProRes video footage.
    I’m running FCP 6 on a MacBook Pro with 4GB of RAM.
    I made the animation sequence in a timeline with the following specs:
    720 x 576 CCIR 601/DVPAL (5:4)
    pixel aspect: PAL CCIR 601
    field dominance: Upper Odd
    Compressor: Uncompressed 10-bit
    (because it created the least pixelated images – after re-sizing them all in Photoshop)
    I have nested the sequence (which has one lone music track accompanying it), so that I can re-size them all using the wire frame in my original sequence.
    The Sequence they are going to is:
    1920 x 1080 HDTV 1080i (16:9)
    pixel aspect: Square
    field dominence: Upper Odd
    Compressor: Apple ProRes 422
    They BOTH have a Audio Sequence settings of 48khz, 16-bit, Channel Grouped.
    When I copy and paste the nested sequence into my documentary sequence it gradually goes out of sync with the music. They both start where they are meant to but it all seems to go out pretty soon. I also tried just bringing in the visuals, then copy and pasting the un-nested sound, but it still happens. I can’t notice any extra footage, which is confusing as both pieces are still the same length.
    Is it the different sequence settings that’s causing the problem? If so is there anyway to rectify the situation without starting again? I tried changing the sequence settings of the animation to the be the same as the rest of the film, but would like to avoid this as it seemed to mess with the picture quite a lot.
    Any help much appreciated!!! And sorry for the essay 🙂
    Thanks so much,
    Tali
    Tali Clarke replied 16 years ago 1 Member · 0 Replies
  • 0 Replies
