Activity Forums AJA Video Systems out of sync LHi
  • out of sync LHi
    Posted by Jim Curtis on June 6, 2011 at 8:43 pm
    I’m having a hard time figuring this out. My A and V get out of sync, and stay 4-6 frames out of sync on this 25 min. short I’m cutting. Not sure what to blame. I have the latest AJA driver, super-fast RAID, all ProRes 422 footage, sequence all rendered, Unlimited RT on, etc.
    If I export a QT movie, and play it in AJA TV, it plays in sync. Just not in FCP.
    If I Refresh A/V Devices, it helps for about ten seconds, then it shortly drifts out of sync again.
    Is there an offset setting in FCP to adjust for video delay? There’s a setting in System Preferences > Playback Control > Frame Offset. But, it doesn’t appear to do anything. I can set it to 0 or 30, and I get the same response out of the LHi.
    Any ideas?
    Jim Curtis
    Jim Curtis
    jamesphilipcurtis.com
    MacPro (Harpertown-Early 2008) 2×4 3GHz; 32G RAM all the same brand; 10.6.3; QT 7.6.6; FCS3; Kona LHi in PCI slot 3 (8.1.1); Primary display: 30″ ACD; Monitoring: Kona LHi SDI to AJA HDP2 converter to HDMI on the HP DreamColor.
    Chad Tingle replied 15 years, 3 months ago 2 Members · 1 Reply
  • Chad Tingle
    June 8, 2011 at 3:59 pm
    [Jim Curtis] “s there an offset setting in FCP to adjust for video delay? There’s a setting in System Preferences > Playback Control > Frame Offset. But, it doesn’t appear to do anything. I can set it to 0 or 30, and I get the same response out of the LHi.”
    Go into system settings… Playback control and you will find the frame offset.
    Chad Tingle
    Producer/Editor
