Activity Forums Adobe Premiere Pro out of sync don’t know why
  • out of sync don’t know why
    Posted by Ditha Angraini on February 24, 2007 at 2:32 am
    Hello…
    I just finished a project on PP2.0, it played great on PP and also when I exported it to avi or m2v. But once I burn it to dvd, a part of it is out of sync. I’ve re-checked it on PP, have re-exported it, and it’s still doing it. I don’t know what else to do. Any suggestion?
    Thanks a lot.
    to learn the true meaning of victory, go and ask the defeated warrior
    Ditha Angraini replied 19 years, 6 months ago 3 Members · 5 Replies
  • Aanarav Sareen
    February 24, 2007 at 3:34 am
    Project settings?
    Media settings?
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Ditha Angraini
    February 24, 2007 at 3:42 am
    The project is DV PAL 25p.
    I exported the movie to DVD using PP. And also have tried using Encore, both set for PAL 25p.
  • Ditha Angraini
    February 24, 2007 at 3:44 am
    I exported as Microsoft DV avi at 25p, and also to MPEG-2 DVD using Media Encoder, also PAL High Quality 4:3.
  • Mike Velte
    February 24, 2007 at 1:14 pm
    Is all your footage DV PAL @ 48,000 Hz audio sample rate?
  • Ditha Angraini
    February 25, 2007 at 10:36 am
    Yup it’s all the same.
    I managed to sort the problem out (finally!!! yay!), I re-import the clips that were having problem, only did minor adjustments to it, and exported to dvd, it worked fine… some people had suggested me to re-capture the footage, but I thought I’d give it a try by re-importing it and if that doesn’t work, then I’d re-capture. And it worked, so I’m very happy.
    Thank you 🙂
