Activity Forums Adobe After Effects Out of Memory Message
  • Out of Memory Message
    Posted by Aaron Leong on March 12, 2008 at 7:25 am
    I’m rendering HDV 1080i60 footage out of After Effects onto an external drive (197GB available) and somewhere along the line After Effects stops the render and gives “Out of Memory” message. Project is 24 layers deep, 13 layers of video (1 video at any given time), 10 layers of stills (2-4 at any given time), top layer is a mask (.psd file).
    I’m running 3.2Ghz 8-core, 10Gb RAM. The ‘memory & cache’ is default 120% of 3.0GB and 60%. How do I keep the message from coming up???
    Thanks in advance for any help!!!
    Aaron Leong replied 18 years, 6 months ago 2 Members · 3 Replies
  • Darby Edelen
    March 12, 2008 at 3:50 pm
    [Aaron Leong] “HDV 1080i60 footage”
    Is your source footage HDV? I’d recommend transcoding to a different codec (HDV uses MPEG-2 compression, and AE doesn’t like that so much).
    Other than that, pre-render anything you can get away with, check the ‘secret preferences’ as Dave suggests, enable the disk cache and if you have multiprocessing disabled, try enabling that (I don’t think it will help the problem, but things should move faster).
    Does AE fail at pretty much the same time in the render every time? I would guess that it is. In that case AE is having trouble rendering one particular layer in your composition that may be effects heavy, the nature of AE’s renderer is such that if AE can render the most RAM intensive layer in your composition without any trouble then it should be able to render the entire composition without trouble (this can be complicated when you have 3D shadows, since these contribute to memory requirements significantly and only appear when multiple layers ‘interact’ with each other).
    Related articles:
    https://livedocs.adobe.com/en_US/AfterEffects/8.0/WSF13D6BED-C53B-408a-B2D6-C8B4205D4FB7.html
    https://livedocs.adobe.com/en_US/AfterEffects/8.0/WS9F936D13-E76A-41e4-BF8F-577132AB4723.html
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Aaron Leong
    March 12, 2008 at 5:52 pm
    My source footage is HDV. I’ll try the secret preferences. And AE stops at different times. Once it stopped at a couple hundred frames, another it got to 5000 and froze. I had to force quit. Thank you for all of your help.
  • Aaron Leong
    March 14, 2008 at 9:21 pm
    Okay, for those that are still reading this, I talked with Adobe, and After Effects 7.0 is not able to work with intel based macs which is why it can only render projects up to a certain length. Sorry for the post, just thought it might be easier to find an answer here or maybe someone here found a work around.
