Activity Forums Apple Final Cut Pro Legacy “Out of Memory” message when rendering.
  • “Out of Memory” message when rendering.
    Posted by Natalia Andreadis on February 26, 2009 at 12:46 pm
    Hello!
    It’s my first time working with 4k footage (shot on a Red One) and I’m having some trouble rendering.
    I only have 3 stills, one quicktime proxy clip and some transitions on my timeline yet I can’t render without “Out of memory” coming up. However, I have 10GB of memory and the stills are all in RGB color space.
    One of the stills was created from a proxy clip. Does that still need special formatting perhaps?
    I’ve edited many projects before without ever having this problem, but none of them used Red One footage…
    I work on FCP 6.0.5 on a Mac Pro using OS X 10.5.6.
    I know little about troubleshooting computer hardware or how it relates to FCP so I’d really appreciate any ideas or help you can give me! Thanks!
    Jody Leggio replied 17 years, 1 month ago 7 Members · 10 Replies
  • 10 Replies
  • Kent Stipp
    February 26, 2009 at 3:56 pm
    Hi
    here is an article published by apple in regards to Ram and Final cut I hope it is of some use to you
    https://support.apple.com/kb/TS1957
    Life Begins at 155mph
    Catch it edit it View it
    3am Studios llc.
    3amstudios.org
    Sharedsummitsfever.com
  • Aaron Neitz
    February 26, 2009 at 4:00 pm
    I recently worked on a 1080 video that had multiple 4K and larger stills. I’d get the memory error too. Try rebooting and closing every sequence except the one you’re rending.
    FYI, FCP can’t use more than 2.5GB of RAM. It’s limited by old code.
  • Natalia Andreadis
    February 26, 2009 at 4:29 pm
    Unbelievable, and after many hours on the phone with fcp support, it turns out that ProRes 422 (HQ) has problems with jpeg files. I transfered all the stills to tiff and now everything works perfectly. How bizarre!
  • Natalia Andreadis
    February 28, 2009 at 10:42 am
    Sorry to say, the problem ended up being only delayed. The tiff files are smaller so the “out of memory” message has come up again as the filters or transitions added up on my project. Any ideas?
  • Doug Nichol
    March 13, 2009 at 8:40 pm
    Hi – did you ever figure this out? I have been having the same problems – getting the “out of memory” message when trying to render even simple sequences (3 layers) no stills. I have the same set up as you 10G ram in a MacPro and working in ProRes HD.
    Thanks.
  • Joe Procopio
    March 23, 2009 at 8:49 pm
    FCP support???????????????? who is that? I thought Creative cow WAS FCP support, lol.
    Broadway Video, NYC
    AVID/FCP editor/engineer
  • Natalia Andreadis
    March 28, 2009 at 5:31 pm
    Hello!
    Nope, sadly I never did fix it… I may have understood it though.
    I removed the stills and since then it has rendered normally. At first, I simply downres-ed the stills but that just delayed the message popping up. I guess that smae as the stills, the 3 layers may be too much for fcp to handle as it can only use 2.5 GB max. They’d better hurry up and improve on that cos it’s damn unpractical!!
    Good luck… Please let me know if you do fix it…
  • Jason Lyons
    April 20, 2009 at 6:03 pm
    Same problem here… Makes me feel like Im working on a PowerMac 9600 AVID, not a 8-core mega giga flippity flop computer..
    UGHHHH Its things like this that really go “Really??” I guess Im wondering outloud, again, like so many other people, what the long term plans if any for the “PRO” apps..
  • Jody Leggio
    August 14, 2009 at 8:51 pm
    Not sure if this will help anybody now, but I had the same problem with rendering stills which lead me to this post. Try working in DVCPRO HD instead of Apple Pro Res. I noticed that everyone having the problem seemed to be using pro res (as I was), so I copied my work into a DVCPRO HD sequence and rendered all of my stills with no problem. I’ve worked on a few shows that started out using Apple Pro Res and changed to DVCPRO HD mid-stream. I think the show I’m working on now is going to do the same beginning with the next episode.
  • Jody Leggio
    August 14, 2009 at 8:52 pm
