Activity › Forums › Adobe After Effects › “Out of Memory” message
  • David Johnson
    February 25, 2010 at 11:35 pm
    Dave’s suggestions are definitely the first things to correct … I’ll just add that, since you mentioned an odd-numbered amount of RAM, there seems an increased chance that you have a mix-match set of RAM sticks … once you rule out the more obvious possibilities, you may need to consider whether your system is having RAM issues in general that are unrelated to AE, but that affect AE.
