Activity Forums Apple Final Cut Pro Legacy Out of Memory
  • Posted by Mark Mulcaster on May 26, 2009 at 10:19 pm
    Hi guys
    Im running Final Cut Pro with 8GB of ram, on a xsan server (with about 16tb total capacity
    Im working on a 48min documentry (in Apple Pro Res 422HQ 1080i)
    The project has several 8 or 9 minute seqences and a wealth of bins.
    Recently when ive been opeing FCP in the morning the servers taking a good 5 to 10 minutes to load the project and then when it does and i select a sequeance i receive an error message saying Out of Memory….
    The FCP project (which in itself is 89megs in size) is copied from the server to the desktop each morning and then saved back at night (we discontinued using FCPS a short while back and have adopted a simplified folder workflow)
    I dont run any other applications in the background when running FCP but i seem to be getting the Out of Memory message more frequently.
    Any ideas on how i could reduce this from happening, it seems a little odd as there isn’t any sequences open or any media in either source or record monitors.
    Suggestions, and speculations are most welcome!
    John Fishback replied 17 years, 2 months ago 3 Members · 2 Replies
  • Tom Meegan
    May 27, 2009 at 2:34 am
    Try breaking your project into several smaller projects and see if the problem persists.
    Large project files can cause the behavior you describe.
    Best,
    Tom
  • John Fishback
    May 27, 2009 at 2:07 pm
    Check this thread. https://forums.creativecow.net/thread/8/1037169
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
