Activity › Forums › Apple Final Cut Pro Legacy › Out of memory
  • Posted by Craig Johnson on February 9, 2014 at 1:49 am
    My project is finished but 3 tiny places wont render. 2 are photos. They are large but so are the 367 other photos in this 90 minute film. They are RGB jpegs. They were rendered many times in this film before today. I tried deleting and putting them back in. Same issue. In addition, there are 3 cross dissolve transitions that are doing the same thing. They wont render. Again delete, add, same issue. I have the same photo size with those same transitions throughout the entire film. These are not grouped up either, very random. Any guesses.
    Dave Farrants replied 12 years, 7 months ago 3 Members · 5 Replies
  • Shane Ross
    February 9, 2014 at 9:30 am
    FCP has issues with photos that are larger than 4000 pixels on any side. Make them smaller.
    Shane
    Little Frog Post
  • Craig Johnson
    February 9, 2014 at 5:10 pm
    The photos are only half that size and like I said, they have rendered in earlier cuts of this same project. Why would a couple of cross dissolve transitions give me “out of memory” messages?
  • Dave Farrants
    February 9, 2014 at 7:00 pm
    I had a similar problem, just a couple of stills that previously rendered failed, tried everything to fix it even trying to render in sections and export as a SC movie section then re-import, finally solved it by changing the few stills files that failed to render to .png’s.
    Web – https://www.foxvideo.co.uk
    Blog – https://foxvidpro.blogspot.co.uk/
  • Craig Johnson
    February 9, 2014 at 7:22 pm
    That’s ridiculous. I did what you suggested and it works fine. Thanks! How!? Why???? I just grabbed the photo in my bin, changed .jpg to .png, dropped the change in the timeline and boom. Renders fine. I have been 2 days trying to get 1 photo out of hundreds that were processed identically to render. Fcp and me are having marital issues. Premiere???
    Thanks again for the gold nugget!
  • Dave Farrants
    February 9, 2014 at 7:38 pm
    Don’t know the answer why, it just worked for me after spending hours trying to fix the problem, glad it worked for you.
