Activity › Forums › Adobe After Effects › out of focus
  • Mark
    December 14, 2006 at 6:43 pm
    Hard to tell from a still what is going on….if the spheres are moving and motion blur is set to the right shutter, then yes this can be done….
    Mark
  • Jatin Makwana
    December 14, 2006 at 6:55 pm
    i kind of mean.
    if i have a still/video shot of lights (traffic lights for example)- No motion.
    How can i then treat that video/still, to acquire this kind, of deeply out of focus effect.
    The kind of effect you would get if you shot a light out of focus.
    Hope that
  • Mike
    December 14, 2006 at 7:47 pm
    The quickest way I know of to achieve this effect is with either Tinderbox or Sapphire. These plug-ins have lens blurs that will bloom the highlights as you defocus which will simulate a true camera lens. There are also more specific settings for diaphragm shape and chromatic aberration that can help you fine tune this effect.
  • Jatin Makwana
    December 14, 2006 at 8:23 pm
    thanks. i’l try them
  • Danny Princz
    December 14, 2006 at 9:10 pm
    also, you can try the lens blur plugin that comes with AFX 7
  • Jatin Makwana
    December 14, 2006 at 11:09 pm
    i feel the lens blur gives the light too much of a soft feathered edge. also image brightness drops.
    tinderbox is pretty good. still not as sharp edged as i would like it.
  • Chris Smith
    December 14, 2006 at 11:32 pm
    Also try “lenscare” which is the best lens blur simulator out there. But if you’re not going to rack focus, then I would just create the shapes with a mask on a solid and mess with transparencies so the edges are brighter than the core of the shape. Also add a little mask feather to smooth the edges. Then use that as a custom particle in Particular, set the colors to be varied and add a small. Lastly add the Glow effect over the particular output and possibly set the layer to ADD transfer mode over tour BG.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Chris Smith
    December 14, 2006 at 11:56 pm
    Here’s a quick test of what I described in the previous post:
    https://sugarfilmproduction.com/blur1.png
    https://sugarfilmproduction.com/blur2.png
    https://sugarfilmproduction.com/blur3.png
    Also those effects are from what is called “Circles of confusion”. Here’s the Wiki on them:
    https://en.wikipedia.org/wiki/Circle_of_confusion
    Chris Smith
  • Chris Smith
    December 14, 2006 at 11:58 pm
    Here’s the scene file as well:
    https://sugarfilmproduction.com/blur.aep
    Need AE7 + Trapcode Particular
    Chris Smith
  • Jatin Makwana
    December 15, 2006 at 1:14 am
    thanks mate. you really shouldnt of. well i hope lots of other people on here have learnt from your expertness too.
    thanks again.
