Activity Forums Apple Final Cut Pro Legacy out if memory
  • Posted by Mark Dershowitz on October 20, 2006 at 4:32 am
    Hello everyone, and thanks for being here. My companyhas just perchaseed a new Mac pro, with 1 gig, of Ram, and a 2ghz, porcessor. everytime I try to open my project nothing opens except for the clps, and sequences window. if I try to open them FCP gives me a out of memory window. It opens fine, when its opened on my powerbook, or a Dual 1.8ghz, G5 with 2gigs ram.I called apple with the problem, they told me to open the project with a system that can, change the project name, and export the project as a XML, I tryed this and nothing happend just the same thing out of memory, I dont know what to do. Does anuone have any ideas. Thanks Mark Dershowitz
    Mark Dershowitz replied 19 years, 10 months ago 3 Members · 6 Replies
  • Tim Counihan
    October 20, 2006 at 5:04 am
    I have seen this bug many times in FCP. The solution is to right click and choose the first command “Open Timeline”.
    That will fix the problem.
  • Mark Dershowitz
    October 20, 2006 at 2:09 pm
    No that didnt work, I cant understand this. Any other ideas.
  • David Roth weiss
    October 20, 2006 at 4:45 pm
    Mark,
    1 gig of RAM is certainly not enough to run FCP. Is that your only problem? I can’t answer that, but ultimately you will have to up the RAM.
    DRW
  • Mark Dershowitz
    October 20, 2006 at 4:55 pm
    its not memory, trust me
  • David Roth weiss
    October 20, 2006 at 5:01 pm
    Okay Mark, I trust you, but what version of FCP have you installed on the Mac Pro???
  • Mark Dershowitz
    October 20, 2006 at 5:07 pm
    FCS 5.1.2
