Activity › Forums › Apple Final Cut Pro Legacy › Ouicktime format for DVD
Posted by Delano Bryant on September 6, 2007 at 2:56 pmIf I Export a sequence into QT to then take into compressor(Thanks David). What are the best QT settings from the FCP timeline? I will then use best encode in compressor for DVD.
Is that the color red you want to use?
Gina Giambone replied 15 years, 7 months ago 6 Members · 17 Replies -
Walter Biscardi
September 6, 2007 at 3:44 pmFrom your timeline:
Export > Quicktime Movie > Current Settings
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Tom Brooks
September 6, 2007 at 3:47 pmUse Export/Quicktime Movie as opposed to Export/via Quicktime Conversion. The best settings are the settings used by your sequence–in other words, select “Use Current Settings.”
Then you may choose to “Make Movie Self-Contained” or not. Selecting this will make a new movie based on a copy (?) of the media for your sequence but does not result in another generation of compression. If you do not select this, your movie will simply be a pointer which references the media existing on your scratch disks. The only problem with that “reference movie” is that sometimes media gets moved and then the reference movie will error out when it tries to play. It’s your choice…reference movies save time and drive space. Self-contained movies are completely portable.
Do not select Recompress All Frames.
Oh, and remember to Export All Markers, as David reminds us. By the way, I have found that judicious use of Compression Markers in a sequence can improve encodes, but this relates more to Web video than DVD.
Direct the resulting movie to a folder of your choice and you’re ready to go to Compressor. Meanwhile, FCP won’t be tied up during a long encode. Hope that’s not too much info. Hey, I’m taking lunch, so there it is.
Delano Bryant
September 6, 2007 at 3:52 pmThanks guys. I’ve got that part down. WHat I was wondering if it made a better encode if at the time of choosing use current settings,,, I chose a better codec if I had a lesser setting on my timeline? Or, is that something you change your settings of your sequence and then media manager or re-render the timeline and then do your export?
Walter Biscardi
September 6, 2007 at 3:56 pm[hdfilmmaker] “WHat I was wondering if it made a better encode if at the time of choosing use current settings,,, I chose a better codec if I had a lesser setting on my timeline?”
The best export is the exact same setting as your timeline as I said in my first post. Anything else adds additional conversion and compression.
Delano Bryant
September 6, 2007 at 3:58 pmok, when do you up an upres of a seq?
Walter Biscardi
September 6, 2007 at 4:38 pm[hdfilmmaker] “ok, when do you up an upres of a seq?”
I don’t honestly know what you’re asking.
For making a DVD, the cleanest export from FCP is staying the same format as your timeline.
David Roth weiss
September 6, 2007 at 5:03 pm[hdfilmmaker] “ok, when do you up an upres of a seq?”
Are you asking about posts advising people who are editing video with the DV codec, where myself and others often advise them to finish uisng 8 or 10-bit uncompressed in order to preserve the quality of their graphics and text?
David
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ?
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
Greg Ball
September 6, 2007 at 5:08 pmI’ve had the opposite request from a client. I edited a program as 8 bit un-compressed. The client wanted to author themselves so they asked me for a DV quicktime. Now of course they are complaining because the graphics are jagged. I told them it’s a result of compressing the file to DV. Is that correct?
David Roth weiss
September 6, 2007 at 5:12 pm[greg] “I told them it’s a result of compressing the file to DV. Is that correct?”
Absolutely!!!
David Roth Weiss
Director/Editor
Walter Biscardi
September 6, 2007 at 5:13 pm[greg] “Is that correct?”
Yep.
They didn’t need you to downconvert the sequence if they have Apple Quicktime.
