Activity Forums VEGAS Pro OT…using Canopus DV card with WIN 7
  • OT…using Canopus DV card with WIN 7
    Posted by Ted Snow on July 10, 2011 at 6:44 pm
    Well I got my new VEGAS computer put together and all is running great. The only problem so far that I ran into is the fact that there are no WIN 7 drivers for the Canopus ACEDVio card which I use as my DV to analog out to my video monitor (not PC monitor). There is a work-around which I found here in case any of you have ran into the same problem.
    https://wp-sandbox.crackingmedia.com/?tag=canopus-acedvio
    It’s as simple as changing the driver to the legacy driver.
    Ted Snow replied 15 years, 2 months ago 3 Members · 5 Replies
  • John Rofrano
    July 10, 2011 at 8:40 pm
    Thanks for letting us know. Too bad there isn’t a way to make a stickey or add to a FAQ. But at least it should be available should someone search.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Graham Bernard
    July 11, 2011 at 3:23 am
    I’m in the exact same position.
    I’ve/I’d thought that I’d thought this through, and came to the conclusion that if I’d ever needed to capture DV tape I’d use the now to be redundant PC to do it. I had NOT remembered that I now use one of the ACEDVio ports as an analogue stream out to my JVC CRT 15″ 700 line colour correcting/grading monitor!!!!
    This was a very timely post of yours and potentially a life saver too. As the link says, this card still has much work to do.
    Very helpful post and a cracking good link too. All I need to do is to withdraw the ACEDVio card from Pc A and insert in Pc B.
    Cheers
    Grazie
  • Graham Bernard
    July 11, 2011 at 3:52 am
    Very timely post. Exact same position as I.
    Grazie
  • Graham Bernard
    July 11, 2011 at 3:59 am
    I’ve/I’d thought that I’d thought this through, and came to the conclusion that if I’d ever needed to capture DV tape I’d use the now soon to be redundant PC to do it. I had NOT remembered that I now use one of the ACEDVio ports as an analogue stream out to my JVC CRT 15″ 700 line colour correcting/grading monitor!!!!
    Cheers
    Grazie
  • Ted Snow
    July 12, 2011 at 5:05 am
    I still see these cards for sale under the name Grass Valley (Canopus)…but do state in the specifications that the supported operating systems go up to XP Pro. I am surprised that the company has not came up with updated drivers. I am assuming that Grass Valley bought out Canopus. I see that they still have this card listed on their website
    https://www.grassvalley.com/products/acedvio
    but even there it states WIN 2000 or XP in the system requirements, but not WIN 7.
    ASUS P8P67 Deluxe
    EVGA GeForce GTX 560 Ti
    Intel i7 2600k
    Corsair HX750 power supply
    Two Seagate Barracuda 500g drives
    16 Gig G.Skill Ripjaws DDR3 1600
    Thermaltake V9 BlacX Edition case
    Xigmatek Dark Knight CPU Cooler
    Win 7 Pro
