Activity Forums Apple Final Cut Pro Legacy OT-Understanding amps
  • OT-Understanding amps
    Posted by Scott Davis on July 2, 2008 at 1:24 am
    I’m interested in buying a rackmount power distribution unit from Trip Lite. They offer a 15 amp and a 20 amp unit. Which is necessary for connecting a few FW drives, a small deck, an external SATA RAID, and some misc other equipment in a small rack.
    Scott Davis
    Scott Davis replied 18 years, 2 months ago 3 Members · 4 Replies
  • Walter Biscardi
    July 2, 2008 at 2:10 am
    [Scott Davis] “Which is necessary for connecting a few FW drives”
    15 Amp is more than enough. Our entire facility with everything turned on only runs 33 Amps and that’s three full edit suites and 7 VTR’s.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Scott Davis
    July 2, 2008 at 2:12 am
    Thanks Walter, much appreciated the wiki entry was way beyond my understanding.
    Scott Davis
  • Steven Gonzales
    July 2, 2008 at 3:08 am
    Power (P) measured in watts = Current (I) measured in amps * Electromotive force (E) measured in volts.
    So a 45W power draw (the transformer on this portable computer I’m using), from a Electromotive Force source of 120 Volts (approx. supply in the US), would be a Current (I) of 45/120, or .375 Amps (I).
    So if you add up all the power of the devices you’re plugging in, and divide that by 120 (or even 100, to give yourself a 20% margin) then you’ll know how many amps you’re drawing.
    So using that 100 volts with it’s margin of error, you would not want more than 2000 watts on a 20 amp circuit, or 1500 watts on a 15 amp circuit.
  • Scott Davis
    July 3, 2008 at 12:29 am
    Thanks Steven, one other question: How do you find out how much power is being used by your devices?
    Scott
    Scott Davis
