Activity Forums Apple Final Cut Pro Legacy OT – Teranex Upres Samples???
  • OT – Teranex Upres Samples???
    Posted by Max Frank on December 11, 2007 at 10:44 pm
    Despite my best attempts to Google, I can’t find what I’m looking for.
    I need to demonstrate to my team how the Teranex system successfully upresses 4×3 SD footage to HD.
    So I’m looking for video and/or image samples of before-and-after shots of the SD/HD footage.
    Has anybody come across any samples of the Teranexs’s work and can you direct me to a link or two?
    Thanks in advance,
    Wayne
    PS – [I know a Teranex upres is not as good as shooting HD, but our project uses a ton of SD stock footage we need to upres]
    Shane Ross replied 18 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Walter Biscardi
    December 11, 2007 at 10:47 pm
    Do you mean also stretching it out to 16:9? I’ve not seen anything like that. It’s going to stretch out just as if you did it with FCP.
    If you’re just trying to go from 4:3 SD to Pillarboxed HD, then the Terranex is fine.
    As for samples, not sure where to look other than the Terranex website for shows that use the tool.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Jeremy Garchow
    December 11, 2007 at 10:56 pm
    [walter biscardi] “As for samples, not sure where to look other than the Terranex website for shows that use the tool.”
    Simply turn on TNT HD.
    Jeremy
  • Shane Ross
    December 11, 2007 at 11:30 pm
    Well, if you watch Blood Diamonds on History Channel, that is FULL of DV, VHS and betaSP upconverted. I can’t post links to it or anything.
    Shane
    Littlefrog Post
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.lfhd.net
  • Max Frank
    December 11, 2007 at 11:49 pm
    Thank you all for the replies.
    I’m not in the US so I can’t view the shows you’ve mentioned.
    Shane, wasn’t Blood Diamond the show you worked on?
    How would you describe the job the teranex did?
    Wayne
  • Max Frank
    December 11, 2007 at 11:52 pm
    Wayne
  • Max Frank
    Wayne
  • Shane Ross
    December 11, 2007 at 11:56 pm
    Yes, I worked on that.
    We used the Terranex to up convert all the DV and VHS and BetaSP footage. Well, not ALL the DV footage, as there wasn’t too much. Some use used Compressor. BUT, what we did was make select reels, used the terranex to upconvert and convert the frame rate from 29.97fps and 25 fps to 23.98 fps (we had some PAL footage). It looked GREAT. Just watch the show.
    It isn’t available on iTunes though…but Andrew Jackson is…
    Shane
    Littlefrog Post
    http://www.lfhd.net
