Activity Forums Apple Final Cut Pro Legacy OT: TC DV to VHS
  • OT: TC DV to VHS
    Posted by Chip Hess on March 8, 2006 at 12:56 am
    Hello all;
    A bit OT, sorry.
    I need to dub screeners
    from Mini DV to VHS for a client.
    I know I can use FCP to add TC,
    but would rather not chew up drive space
    and time for capture, etc.
    Other than using the unreliable control track
    for reference, is there a gizmo available
    to add TC in-between?
    thanks!
    Chip Hess replied 20 years, 6 months ago 3 Members · 3 Replies
  • Walter Biscardi
    March 8, 2006 at 1:08 am
    You mean burn in TC for viewing? Just turn on the display on DV deck and roll to the VHS machine.
    If you want to actually add TC to the VHS tape, I know S-VHS can do this with a professional VHS machine, but I don’t know if regular old VHS can do this.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Steve Wargo
    March 8, 2006 at 1:54 am
    Depending on your playback device, you should be able to output TC in the display like Walter suggested. On some devices, it only displays on the composite connection. If you can see it on a monitor, you can transfer it to a VHS cassette.
    If this doesn’t work, get back to us with more info on your decks, cameras, etc.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
  • Chip Hess
    March 11, 2006 at 10:15 pm
    Steve;
    I am dubbing directly from my cam,
    a JVC DV500 to VHS. Have gone through
    all menu settings and I’ll be darned
    if I can come up with anything.
    I am taking sig from composite, too.
    May just have to go with reading control track.
    Thanks for the replies, all!
    Chip
