Activity › Forums › Apple Final Cut Pro Legacy › OT: super long DVI run
  • OT: super long DVI run
    Posted by Aaron Neitz on October 1, 2007 at 4:01 pm
    I know the Gefen products will work great for a 75′ run of DVI (either fiber optic cable or DVI booster) but has anyone used products from a less expensive company? running 2 DVI monitors at this length is going to cost $2000… ouch.
    Aaron Neitz replied 18 years, 12 months ago 4 Members · 8 Replies
  • 8 Replies
  • Walter Biscardi
    October 1, 2007 at 4:09 pm
    For a straight DVI cable, I have nothing that works over 35′ and I tried a whole bunch of cables. I have a pair of 35′ cables that work just fine, about $350 or so for the pair.
    We tried a whole myriad of products for our 75′ run and nothing worked except the Gefen units. About $1,500 to run the two monitors and USB connection, but it does work and it’s the only thing I’ve found that truly works.
    We have the Gefen 5500 unit.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Russell Lasson
    October 1, 2007 at 4:48 pm
    We use Gefen also. But we did have two of the fibre cables go out on us after a year:(
    We’re looking to replace them with the ethernet cable extenders.
    -Russ
  • Walter Biscardi
    October 1, 2007 at 4:50 pm
    [Russell Lasson] “We’re looking to replace them with the ethernet cable extenders.”
    That’s what our 5500 unit is. No fibre cables, just cheap Cat-5.
  • Russell Lasson
    October 1, 2007 at 5:04 pm
    After having two fibre cables go bad, I totally thing the 5500 is the way to go. Plus you can customize the length. It’s so nice not having our noisy towers in the edit bays!
    -Russ
  • Aaron Neitz
    October 1, 2007 at 5:51 pm
    For the premium price you’re paying for fiber cables…. they should NEVER go bad! I’d be pretty torqued.
    Will look into the 5500’s, thanks!
  • Russell Lasson
    October 1, 2007 at 5:59 pm
    It definitely upset me! I won’t make the same mistake again.
    -Russ
  • Sean Oneil
    October 1, 2007 at 6:45 pm
  • Aaron Neitz
    October 1, 2007 at 8:17 pm
    Can I ask what brand you were using? The Gefen maybe???
    We just bought a new Flame system…. and autodesk set us up with an Avenview fiber DVI cable. It’s working great, and I tend to assume autodesk does their homework when buying peripherals for premier systems.
