OT – Sony vx2000 menu settings erased
Posted by Charles Avanti on January 19, 2008 at 7:54 pmBoth of my two Sony vx2000’s have developed the same problem at the same time.
I store my cameras with a charged battery attached so the menu settings donAccountclosedduetonorealnameused replied 18 years, 8 months ago 4 Members · 4 Replies -
Edward Troxel
January 19, 2008 at 11:28 pm -
Tom Pauncz
January 20, 2008 at 7:15 pmAbsolutely correct. I had the same problem with my VX2000. As soon as battery was removed and reinserted and the camera turned on, the display showed “CLOCK SET”.
Unfortunately the lithium battery, like in a computer that keeps the CMOS settings, is not user accessible/serviceable.
SONY factory repair here in Toronto charged $50 labour and $18 dollars for the battery. Took a week to get it back.
Tom
Edward Troxel
January 20, 2008 at 8:31 pm -
January 29, 2008 at 5:15 amI have had a VX2000 for several years and have not yet had to replace the battery. I thought that I heard that if you charge the normal battery on the camera that it will also charge the internal battery. So instead of charging my batteries on the external charger, I will every so often charge them on the camera or just use the camera to capture footage with the camera plugged in.
