Activity › Forums › AJA Video Systems › OT: Sonnet Fusion Boxes-No build your own anymore!
Posted by Kevin Wild on May 18, 2007 at 6:22 pmJust thought some might be interested in this. After saving a lot of money by building 3 of my own Raids with the Sonnet Tech Fusion 500P boxes, I called today and they said they are now only selling them populated with drives. Argh! It’s too bad…it instantly added $500 to the price now that I can’t get cheaper drives elsewhere.
Interestingly, B&H says they are still accepting orders for the box only for $499. I ordered one but I’m wondering if it will even go through. Per the Sonnet guy I talked with, he says he doubts it unless they have them in stock.
Just an fyi for the diy’s.
Kevin
Lance Bachelder replied 19 years, 3 months ago 6 Members · 15 Replies -
Jeremy Garchow
May 18, 2007 at 7:17 pmYeah, but have you looked at their new ones? AN ATTO infiniband card that supports all kinds of raid on it.
It looks sweet and it’s still priced right. Can’t wait to check it out.
Jeremy
Bob Zelin
May 18, 2007 at 10:24 pmKevin –
do you know why this happens ? Because someone not as qualified as you buys drives from “Joes discount SATA drives” which are some Fujitsu weird model, they stick them in, nothing works, and they call up Sonnet and say “hey, your box isn’t working”, and keep their tech support on the phone for 4 hours. “I gave you guys $499, and nothing is working”. That is why they don’t want to sell empty boxes. This is the reason Cal Digit, and G-Tech don’t sell empty boxes either. If these companies make $75 profit from selling an empty box, should they sit on the phone with you for 2 hours, trying to get your box to work ?bob Zelin
Kevin Wild
May 18, 2007 at 11:13 pmOh, I know why it happens and it’s unfortunate for those of us who (almost) know what we’re doing. 🙂
Okay, Bob. Sign me up for your army in the battle against the inexperienced hacks!
Seriously, it’s too bad. This Sonnet solution was the most affordable way in before. I may now go with one of the other suppliers like Cal Digit if I can’t buy the box without the drives.
KW
Mike Mendoza
May 18, 2007 at 11:18 pmHmmm…. saw this coming. I personaly know lots of “qualified” people, myself included, who had lots of problems with the Sonnet arrays. All of which could have been easily avoided if Sonnet would have listed “approved drives” to use with their boxes. They should have never sold boxes that claim to use standard SATA 3.0 drives if they had no faith these boxes would be compatible.
Basically they should have started selling them populated from the start, if they were not willing to SUPPORT their CUSTOMERS using empty cases.
Are we now supposed to buy our memory, displays, SATA cards, etc from say . . Apple? To avoid any problems? Fooey
I totally support your right to build/expand/modify your own computer system, as many of us do. I can’t imagine how lame (and expensive) my street modified auto and Harley would be if i were to let the factory build it for me?
Jeremy Garchow
May 19, 2007 at 12:23 am[Hector] ” I totally support your right to build/expand/modify your own computer system, as many of us do”
No one is forcing you to buy a Sonnet, get some other cheap enclosure.
There are plenty.
Kevin Wild
May 19, 2007 at 2:34 amI’m fully aware no one is forcing me to buy anything. This string was started to make people aware of the change at Sonnet.
If you have a suggestion for another durable, solid, empty box that will work with Sonnet’s Tempo SATA E4P, it would be helpful.
FWIW, I have 3 edit suites and try to keep all equipment redundant. I have the same mixers, same Kona’s, etc. I would RATHER get another Fusion 500. We’ll see if B&H has them, like my original post said.
Mike Mendoza
May 19, 2007 at 2:41 am -
Jeremy Garchow
May 19, 2007 at 2:49 amSorry, Kevin i was responding to Hector more than you. Please accept my apologies.
Try these:
https://www.macgurus.com/productpages/sata/BurlyPortMultiEncl.php
https://www.usb-ware.com/5-bay-esata-port-multiplier-enclosure.htm
https://www.firmtek.com/seritek/seritek-2eEN4/
The Google search goes on and on….
Jeremy
Kevin Wild
May 19, 2007 at 3:00 amNo problem. I (for some crazy reason) trust the people here to give good suggestions. Much better than searches where everyone has the greatest product…:-)
Hector, thanks for that. I should’ve looked around more to see who carries the empty boxes still. I have one on order from B&H, but might cancel it as it says “available” but not in stock.
Thanks again, guys. Onward!
Kw
Bob Zelin
May 19, 2007 at 1:34 pmthis is a response to Kevin and Hector. I get my boxes from Maxx Digital in California. They carry all the brands, including the “no names”. I always use Hitachi or Seagate SATA drives. When Seagate released the original 7200.9 series SATA drives, there were ALL KINDS of problems due to SSA. I was VERY angry at this time, as everything that I had been doing, stopped working. This change that Seagate made is NOT Sonnet’s responsibility, nor is it Cal Digit’s responsibility, nor is it Firmtek’s responsibility to tell you (and post on their web site) – “hey everyone, Seagate’s new SATA drives have a new feature that is screwing up our product, so make sure not to use it”.
At that time, I got the initial information from Firmtek engineering (even thought I was using a Sonnet product), and then (after yelling at Ron at Maxx Digital), got a direct engineering contact at Seagate, where I got to yell at them. At the time, they sent me a utility to turn off SSA (which wound up not working all the time), and said that the new 7200.10 (which is what is being sold today) does not have this issue.
Does this mean that Sonnet arrays suck ? ABSOLUTELY NOT. This is the aggrivation that EVERYONE IN THE BUSINESS has to go thru. This is an AJA forum, and Leopard is coming. The new Kona 4 drivers just came out. Will there be problems ? ABSOLUTELY. Does AJA suck ? ABSOLULELY NOT. This is the crap that we have to go thru – its easier now than ever before (with SCSI and Fibre). Suffering with technology is an integral part of what we do for a living. Convincing manufacturers that “we are not the only one with the problem” is part of the game.
With that said, Sonnet is a fine manufacturer, and makes great products that I have installed all over the place, that work very reliability. I switched over to Cal Digit for clients that require greater performance, but there is nothing wrong with Sonnet boxes. If you run into a bad batch of drives – that’s life – deal with it, or buy your drive boxes pre-loaded with drives.
You ain’t gonna get rock bottom prices, with killer free support.
Bob Zelin
