Activity Forums VEGAS Pro OT: Recent System Builds – Recommendations?
  • OT: Recent System Builds – Recommendations?
    Posted by Rob Bond on September 11, 2008 at 11:19 am
    Folks,
    My 5-year old P4 is showing signs of hardware problems. I am considering taking the plunge and building my own system.
    Has anyone built a system in the last 3 months or so that can recommend a motherboard/case/power supply?
    I have been looking at motherboards (focusing on ASUS, for no particular reason) and my head is beginning to spin, specifically consider P45 vs x38/x48 based boards. One obvious advantage of the P45-based boards is they support up to 16 MB of RAM, which may be handy in the future with the 64-bit Vegas.
    –Rob
    John Rofrano replied 18 years ago 5 Members · 7 Replies
  • 7 Replies
  • Steve Rhoden
    September 11, 2008 at 11:43 am
    Search this forum…There are tons of posts and reposts
    of recommendations addressing this question.
    Steve Rhoden
    Creative Director
    TNX EFFECTS STUDIOS.
    sample bits at
    http://www.youtube.com/hentys
  • Rob Bond
    September 11, 2008 at 12:06 pm
    Steve,
    Yes there are tons of post on this general topic, but none (that I could find) that specifically speak to my questions.
    So again, input sought from **recent** system builders (as the technology changes least every 6 months) and specifically on choosing a Motherboard (P45-based vs x38/x48 based). Any other tips/recommendations for a first time system builder are welcome (I plan on a Quad Core Intel CPU, two 500 GB HDD, and 8 GB memory)
    –Thanks
    –Rob
  • John Rofrano
    September 11, 2008 at 2:57 pm
    I can appreciate your wanting to get *recent* advice but I can give you the guidelines that I used when I build my QuadCore system (specs here) and it is the most stable system I have even owned. The Intel D975XBX2 motherboard that I built around is still relevant or you can pick the latest Intel DP45SG if you want a P45 board.
    Here is the secret: Get an Intel motherboard with an Intel processor!
    Sounds too obvious right? I’ve built around GigaByte MBs, I’ve built around ASUS MB’s. I always bought their top-of-the-line flagship MB and I’ve always had intermittent problems. Their manuals are written in Chinglish and their customer services is non-existent!
    I built around the Intel D975XBX2 and it has been rock solid. I had a small problem with the hard drive light after the build so I called Intel and in 5 minutes a human who spoke English answered the phone and understood my problem. He said let me check with the lab and get back to you and within 1/2 hr he called back with the fix (something I needed to change in the BIOS). I will use nothing but Intel MBs in the future.
    So here is what you do. Select your Intel Extreme Motherboard of choice. Select a processor that Intel guarantees will work with that motherboard. Go to their Tested Memory page and select memory that Intel has tested with that motherboard (this is very important). Select a power supply that has more than enough power for your MB, CPU, and whatever graphics card you choose. Having enough clean power is critical to having a stable system (don’t skimp here).
    That’s it! Let Intel do all the hard work of testing for you and be sure to stick with the parts that they recommend. This is what I did and I’ve been very happy with my selections.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Rob Bond
    September 11, 2008 at 3:40 pm
    Hi John,
    Great advice, which I greatly appreciate as a newbie to DYI system building. The last thing I want is to be spending lots of time casing down troubles. An Intel-in-Intel approach does make a lot of sense from this perspective.
    What about overclocking with Intel motherboards? Are they overclocking friendly, should I wish to dip my toe into the overclocking waters?
    Finely, any informed speculation regarding possible 64-bit Vegas benefits of getting a (P45-based) motherboard that can grow up to 16 MB of RAM?
    –Rob
    Rob
  • John Frey
    September 11, 2008 at 3:53 pm
    I totally agree with John. I have built 3 systems over the past year with Intel boards and processors. Rock solid systems with great support. I think that plenty of space for ram for the future of Vegas 64 bit is very important. It may not be long before new boards will feature not only Sata, but HDMI and the new USB3 ports as well. Good luck!
    John D. Frey
    25 Year owner/operator of two California-based production studios.
    Digital West Video Productions of San Luis Obispo and Inland Images of Lake Elsinore
  • Jeremy Rasnic
    September 11, 2008 at 7:18 pm
    This is what I built back in April. It is solid and runs like a beast although 32 bit Vegas cannot utilize all 8 cores efficiently.
    The link.
    j razz
  • John Rofrano
    September 11, 2008 at 7:51 pm
    Yes they are. They didn’t use to be but Intel finally realized that people who build their own systems like to overclock and so they make it easy now. If you are going to overclock, make sure you buy a case with good ventilation and use a good CPU cooler (like the ZALMAN that I bought).
    16GB of RAM is an awful lot of RAM for a single user system. I would think that 8GB is plenty but no one knows how Vegas64 will use RAM. If you think you will need it, get the P45 and be safe.
    ~jr
