Activity › Forums › Apple Final Cut Pro Legacy › OT – RAID Question
David Roth weiss
February 23, 2012 at 2:45 pm[Thomas Morter-Laing] “Yes it does, even if theyre the same size, different drives have different ways of working and different levels of cache etc- it may be fine but may go VERY slow. I would get 3 of the same drive.”
Yes, Thomas is correct. Identical drives should always be used in a RAID configuration. And, that means identical in every way… Same brand, same specs, and same size.
David Roth Weiss
ProMax Systems
Burbank
DRW@ProMax.com
http://www.ProMax.comDavid is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
Max Frank
February 24, 2012 at 8:07 amThank you to all who contributed to this helpful thread.
Wayne
Max Frank
February 24, 2012 at 9:46 amI’m baaaack…
Another question, if I may:
I currently have 2 x 1TB Seagate Drives in my Mac Pro – Model: ST31000528AS
That drive is no longer available.They now have a newer drive at the same spec, speed, buffer, etc but a different model number: ST31000524AS
Would I be ok to add the newer-same spec’d model, or do I have to replace all my drives with ones that are identical in every way?
Wayne
Thomas Morter-laing
February 24, 2012 at 9:54 amAs long as the brand, speed, cache and capacity are the same, it should be fine in theory. It’s normally fine anyway, but sometimes not- for example WD Black and Green drives; I think you can get them the same spec (ie cache and ALLEGED speed) but the green drives work very differently, and even though they WILL RAID together, they are pretty unreliable when you do (ie takes ages to get started etc). But you should be fine 🙂
Tom Morter-Laing
Twitter- @TomTheEditor
_________________________________________________
Editor, Certified Apple Product Proffessional, 2010
——————————————-Equipment (not for ‘bragging’, but in case it’s relevant to future posts :D): Canon 7D, with Rode NTG2.
iMac 27″ intel i7 3.4GHz, 12GB RAM, ATI HD 6970M [2GB GDDR5], 2x G-Tech G-RAID (0) 2TB over Thunderbolt via Sonnet Echo ExpressCard/34 Thunderbolt adapter and Tempo™ SATA ExpressCard/34. Elgato Turbo H264HD. -
Rafael Amador
February 24, 2012 at 10:21 amHi David,
I use the RAID-0 just for editing (speed).
I keep all the stuff back up in different HDs.
I start to need something bigger but at the moment I’m waiting where the things are going.
I may end up working with PP on an HP, so time to take it easy and don’t invest.
rafa
