Activity › Forums › Avid Media Composer › OT – problem connect w a MacBook to a Sata raid via USB3 or…?
  • OT – problem connect w a MacBook to a Sata raid via USB3 or…?
    Posted by Paul Dougherty on August 10, 2016 at 12:56 pm
    I was running a Avid on a G5 for legacy NTSC work and the G5 died. I was using a 5 drive raid (not striped but JBOD). As a alternative/replacement I tried a Startech USB 3 0 to eSATA Cable to connect to a fairly new MacBook (w USB3 & Thunderbolt) 2.5 Ghz Intel Core i5 w OS 10.9.5). It only sees one of the 5 drives. I called the person I bought the raid from who I have a high regard for (should have done that earlier) and he seemed skeptical about USB 3 and thought using a Thunderbolt connection / adaptor to would be better. (he suggested the AKiTiO below)
    It’s more expensive and ties up the port I would like to use for a 2nd monitor. Is there anything I can try before I give up on the USB 3 to Sata StarTech adaptor?
    Paul
    AKiTiO Thunder SATA Go Hub SSD Reader with Tethered Thunderbolt Cable and 2x eSATA Host Ports
    I am using the….
    Startech USB3S2ESATA 3 ft SuperSpeed USB 3 0 to eSATA Cable
    Paul Dougherty replied 10 years, 1 month ago 2 Members · 4 Replies
