Activity › Forums › Creative Community Conversations › OT: Premiere CS6 oddity
Posted by Scott Witthaus on January 15, 2015 at 11:34 pmSince this is not a forum about FCPX and there was no response from the PP Basics forum, I figured I might try here:
Working on PP CS6 on a 2013 Mac Pro, totally tricked out. When I drag the playhead around the timeline and then let go the playhead, on it’s own accord, mimics that movement and then settles back to where I left it. Very odd. Being relatively new to PP, is this a “feature” or a bug? It’s not stopping me from working, but a very curious thing to watch. Thanks in advance.
Scott Witthaus
Senior Editor/Post Production Supervisor
1708 Inc./Editorial
Professor, VCU BrandcenterDavid Mcgavran replied 11 years, 8 months ago 9 Members · 16 Replies -
Oliver Peters
January 16, 2015 at 1:43 amI’ve seen a similar type of behavior on some computers. But only on networked machines. It’s basically like your keystrokes are being processed very slowly and the computer is simply executing what you’ve been telling it to do and trying to catch up. I’ve seen it on CC, so evidently whatever it is, it hasn’t been solved. It tends to be intermittent and then settles down after a minute or so. The same machines don’t seem to do this with other Adobe apps, like After Effects.
– OliverOliver Peters Post Production Services, LLC
Orlando, FL
http://www.oliverpeters.com -
Andrew Kimery
January 16, 2015 at 2:05 amKinda like what Oliver said, I’ve seen it with various applications if the machine is struggling (effects need to be rendered, CPU/GPU intensive codec, etc.,.). I’ve only used PPro CC and CC 2014 and if this happened it didn’t do it enough for me to notice. Might be a combination of factors on your end Scott making it happen.
Scott Witthaus
January 16, 2015 at 2:13 amInteresting. It’s about a kick-ass machine as you can buy. I will keep digging. Not stopping me from doing the work, but very curious to watch.
sw
Scott Witthaus
1708 Inc./Editorial
Professor, VCU Brandcenter -
Oliver Peters
January 16, 2015 at 2:22 am[Scott Witthaus] “It’s about a kick-ass machine as you can buy.”
If it’s a current machine and OS, CS6 is no longer optimized for it. Of course, it might work just fine, but not really the best software for it. What type of media are you using?
– Oliver
Orlando, FL
Dennis Radeke
January 16, 2015 at 12:36 pm[Oliver Peters] “If it’s a current machine and OS, CS6 is no longer optimized for it. Of course, it might work just fine, but not really the best software for it. What type of media are you using?”
What he said….
Put a trial of CC 2014.2 and see if it performs better. 10.9.5 or Yosemite.
Dennis
Scott Witthaus
January 16, 2015 at 2:55 pmCan’t do that just yet. But I will as soon as this is all done.
sw
Scott Witthaus
1708 Inc./Editorial
Bret Williams
January 16, 2015 at 9:08 pmIt’s almost as odd as if you add a drop shadow in FCP X, then drag it all around for a bit like you’re trying to decide the best location and then hit undo. FCP X animates all your dragging about in reverse. Ridiculous.
X used to also record all your drags in the color pulldown (not the picker) where you open it and drag the eyedropper around on the palette. You’d drag it around a bit and create about 10 undos a second. But that seems to be fixed. Maybe I’ll go back to using it.
Scott Witthaus
January 17, 2015 at 11:42 am[Bret Williams] “It’s almost as odd as if you add a drop shadow in FCP X, then drag it all around for a bit like you’re trying to decide the best location and then hit undo. FCP X animates all your dragging about in reverse. “
Not sure what this has to do with a Premier bug at all, but thanks for the info. Never noticed it.
Scott Witthaus
1708 Inc./Editorial
John Rofrano
January 17, 2015 at 3:05 pm[Scott Witthaus] “It’s about a kick-ass machine as you can buy.”
Yes, but is it a “kick-ass machine” for that particular task?
If you asked someone what is the most kick-ass Mac you can buy, most people would say the $8K 12-Core Mac Pro. The problem is, that’s only true for multi-threaded tasks. This is because the 12-Core Mac Pro as a 2.7GHz CPU while the 4-Core has a 3.7GHz CPU because as you add more cores, you reduce the power of each core trading off single core performance for multi-core performance. That means the 4-Core is 33% faster at single threaded tasks. So if scrubbing the timeline in CS6 is single-threaded, then a 4-Core Mac Pro will kick the butt of your 12-Core Mac Pro.
Also, Adobe CS6 is the first version to use OpenCL but Adobe locked it to certain AMD cards of that time so I’m guessing that those big beefy AMD D700’s on the new Mac Pro are going completely unused by CS6.
The bottom line being that if you want to fully utilize the latest “kick-ass” system, you need to use the latest software. I too have Adobe CS6 and have no plans to use CC but if you want to take advantage of your new Mac Pro with Adobe software, you’ll need to use CC.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Brett Sherman
January 17, 2015 at 6:38 pm[John Rofrano] “That means the 4-Core is 33% faster at single threaded tasks. So if scrubbing the timeline in CS6 is single-threaded, then a 4-Core Mac Pro will kick the butt of your 12-Core Mac Pro.”
Yes. I find my MacBook Pro snappier than my 8-core Mac Pro in skimming. This is especially true when skimming GH4 .mov footage. My MBP operates about 3X faster than the Mac Pro. My guess is something having to do with MPEG-4 processing and the Xeons is not great. Or maybe better graphic drivers on the MBP? I haven’t exactly figured it out.
