Activity Forums Adobe Encore DVD OT: MPEG2 Size
  • OT: MPEG2 Size
    Posted by Jeffrey Gould on May 19, 2006 at 3:37 pm
    Hi, Can an MPEG2 be any size or does it have to conform to established NTSC/PAL sizes. I’m trying to export a clip from AE to use in a kiosk computer that will be 800×600, I keep getting errors that the size is not compatible with Adobe’s MPEG encoder. Is there a better way to do this? The actual resolution of the monitor is 1280*1024 and I wanted the video the same aspect ratio. Wasn’t sure what forum to post in…so I apologize if it’s the wrong one.
    Jeffrey S. Gould
    Action Media Productions
    Tim Kurkoski replied 20 years, 3 months ago 2 Members · 1 Reply
  • Tim Kurkoski
    May 19, 2006 at 3:47 pm
    All video assets must be NTSC or PAL resolution for Encore to accept them. The DVD spec doesn’t allow anything larger. (Half- and quarter-res are allowed, but Encore doesn’t support those sizes. No one uses them anyway. For more detail: https://www.dvddemystified.com/dvdfaq.html#3.4 )
    If your content is going on a kiosk, you can either live with the video being up-res’d, or you can use a different delivery format than DVD. If no interactivity is required, just use an MPEG, WMV, or QT file. If you need interactivity, consider Flash or Director.
