Activity › Forums › Apple Final Cut Pro Legacy › OT: Medea Help or Bit rate?
  • OT: Medea Help or Bit rate?
    Posted by Scott Witthaus on August 29, 2005 at 7:17 pm
    Hey all –
    got a 300 gig Media VideoRaid RTR that is about 3 years old, hooked
    (scsi) to an older dual 1.2 G4 machine. We have upgraded OSX verions
    (now at 10.3.9) and moved to fcp4.5 over the life of this array. We
    have about 30 gig free space.
    Recently, we have been seeing glitches, droputs, dropped frames when
    playing back off this drive. I reset the scsi connections, run disk
    first aid, etc and all seems good. Still having the maddening
    sporadic problem. Any other ideas? Firmware update? If there is a
    firmware update, do I need to clean the drive off or back up all the
    media before the update?
    ah, and I just discovered that the freelancer brought this material in a 10 bit uncompressed. If I create an 8 bit sequence and render out, will that help with a potential bit rate problem?
    Thanks in advance.
    Scott Witthaus
    Senior Editor/Post Production Supervisor
    Greybox, LLC
    Richmond, VA USA
    http://www.greybox.cc
    Scott Witthaus replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
