Activity Forums Blackmagic Design OT: Mastering advice for universal compatibility (NTSC, PAL, SECAM)
  • OT: Mastering advice for universal compatibility (NTSC, PAL, SECAM)
    Posted by Emery on May 25, 2005 at 5:12 am
    Im doing a show that will be played all around the world and Im wondering what kind of pitfalls I might run into.
    Ive been doing a little research and there seems to be many flavors of PAL (b, g, h etc).
    Final delivery will be on DVD and I need to make sure each one I make will work everywhere.
    Obviously this means making three versions… or does it mean making 10 versions?
    I need to cover all the major countries, which I feel can be done with just PAL and NTSC. But France and Russia use SECAM?
    So my question is, how many formats (or flavors) are out there?
    Does a PAL dvd work with every flavor of PAL dvd player and television?
    All the post will be done in HD (probably DVCPRO HD 720p @ 23.98 fps).
    Emery
    This was cross posted in broadcast design by accident… sorry
    Nick Brenner replied 21 years, 3 months ago 8 Members · 19 Replies
  • 19 Replies
  • Graeme Nattress
    May 25, 2005 at 3:58 pm
    There are only “PAL” and “NTSC” on DVD. There is no SECAM. With regards to PAL and NTSC, they’re really transmission formats and hence the formats supported by DVD are 720×480 @ 23.98fps (NTSC 24p), 720×480 @ 29.97fps (NTSC) & 720×576 @ 25fps (PAL). I think there’s also a PAL 24p format. So really, you only need two versions, 720×480@29.97fps and 720×576@25fps. Unless it’s all from a film source, when you might be better off with the 24p option. It works great on NTSC, but I’ve never made a PAL 24p DVD.
    Graeme
    http://www.nattress.com – Film Effects for FCP
  • Chris Borjis
    May 25, 2005 at 6:32 pm
    Most pal DVD players can play NTSC discs if they are region free (DVD-+R is)
    and if the TV set was made in the last 10 years (PAL 60 mode). NTSC won’t play pal though.
    I’ve made quite a few NTSC discs for our international clients and no troubles were reported on playback in europe.
  • Barend Onneweer
    May 25, 2005 at 6:36 pm
    I’ve never seen (ore heard of) 24fps PAL – if that’s to anyones interest.
    As for SECAM: it’s a broadcast standard. But the all the material fed into the SECAM broadcast is PAL. In France all DVD’s are PAL.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Emery
    May 25, 2005 at 6:41 pm
    Borjis are you telling me any failry new PAL tv can display an NTSC signal?
    The audience for this project is an older group and I cant risk a compatibility issue so I guess my best bet is to make an NTSC and PAL version.
    What are commercial DVDs mastered in for PAL countries? PAL right? What about countries like France and Russia that use SECAM, i imagine their displays and dvd players can handle an NTSC signal? Is a PAL or NTSC DVD better for SECAM countries?
    All the dvds will be burned region 0 by the way
  • Emery
    May 25, 2005 at 6:47 pm
    Thanks Barend, I was just aasking that question below.
    so if im shooting with the Varicam @ 23.98 fps and make an NTSC 24p DVD and a PAL25p DVD i should cover all ground correct?
    As far as I know there is no compatibility issue with 24p vs 29.97, is there?
    I usually make NTSC 24p dvd’s and have never run into compatability issues but this is the first project Ive done that will have thousands of discs sent all around the world so I just want to make sure.
    Emery
  • Graeme Nattress
    May 25, 2005 at 7:07 pm
    A 24p DVD sounds great. I think, according to the DVD SP3 manual, there’s a way to also make a PAl 24p DVD, and the player itself will speed it up to 25fps for you. I’d personally just use Cinema Tools to speed up (conform) to 25fps with the HD media and do a seperate PAL downconvert from that.
    Graeme
  • Chris Borjis
    May 25, 2005 at 7:11 pm
    YES, but the signal MUST originate from a PAL player to make it work.
    It’s my understanding the tolerances between SECAM and PAL are pretty close.
  • Daniel Weber
    May 25, 2005 at 7:31 pm
    I have made lots of DVD’s for International use. We make NTSC DVD’s because like Borjis said, most PAL dvd players can play NTSC discs. It is only the NTSC players in the states that can’t do the conversion.
    From what I have been told, if the DVD player was made in the past couple of years, it can handle NTSC discs. Just make sure that they are region encoded for all the world regions. This is more important than NTSC/PAL format.
    Dan Weber
  • Emery
    May 25, 2005 at 7:33 pm
    thanks graeme, your always a great source of information. Im doing research on a number of tools that could do the downconvert, including your FC plug-ins, compressor, and algoliths HQV processing board.
    Emery
  • Emery
    May 25, 2005 at 7:40 pm
    actually i guess your standards conversion wouldnt necessarily apply to this situation.
