Activity › Forums › Apple Final Cut Pro Legacy › OT: how to embed a movie into e-mail
Posted by Chris Poisson on November 29, 2006 at 1:43 amThis may be WAY OT, but I’ll bet someone here has done this, I want to put a short (less than 1 minute) movie in an email generated in Macmail. It can be any type of file that would work, I have Squeeze and Episode as well as Compressor, so any tips on what type of file to start with would be good.
Basically this is an e-mail greeting card, to be sent to friends and associates, most likely will be opened up on Windows machines.
My problem is I don’t know where to start, what I have to do with the file(s) or anything. I want the movie to just play when the e-mail is opened.
Anyone?
13 replied 19 years, 10 months ago 8 Members · 9 Replies -
Walter Biscardi
November 29, 2006 at 2:14 amI use H.264’s all the time. the end user has to have Quicktime 7 installed, but I email 30 – 60 spots all the time just using the Quicktime 7 Download presets in Compressor.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Chris Poisson
November 29, 2006 at 3:53 amHmmm,
But how do you make it so that the file plays? When I attach QT’s to an e-mail, all I see is the QT icon, not the movie. The reciever has to drag the movie onto their desktop to play it, and what I want is to have it play IN the e-mail.
Steve Eisen
November 29, 2006 at 4:14 amRead Walter’s responce again. Both you and the recipient of the e-mail MUST have QT 7 installed on their system. I send H.264’s via e-mail all the time. I use the same technique as Walter. If my files are to large for e-mail, I will use yousendit.com.
Steve Eisen
Eisen Video Productions
Director-At-Large
Chicago Final Cut Pro Users Group -
Christian Kinnard
November 29, 2006 at 4:43 amHave you tried HTML embeding? A number of years ago I had to create a email mailer “postcard”, where I had to embed graphics/links into an email. It’s a bit tricky, if I remember right you can’t do it through mac Mail, at least you couldn’t then, I had to use my host company mail server (ipowerweb), and the was a setting to create HTML email. Could work, a search on google HTML email will point you in the right direction.
Christian
Enge
November 29, 2006 at 12:41 pmFrom Apple.Inc…
QuickTime: Embedding QuickTime for web delivery
Learn how to embed QuickTime content on an Internet web page.Thetag allows media file types other than those directly supported by the browser to be handled with an external application or plugin. In this case, the external application is QuickTime Player and the plugin is the QuickTime Plugin.
With the release of Internet Explorer 5.5 SP2 and later, you must use anThe list ofattributes is long; here we will document theattributes specific to QuickTime.
The Basic Necessities
Thetag is similar to thetag; they both have a SRC, WIDTH and HEIGHT parameter. These parameters are required and tell the browser the media to be displayed and the width and height of the media specified in the SRC attribute.
For example:The SRC attribute is the media file to display either by an absolute or relative URL. The HEIGHT attribute specifies the vertical size in pixels of the SRC attribute. The WIDTH attribute specifies its horizontal size.
IMPORTANT
In order for the controller to appear properly, add 16 pixels to the height of a movie.For example, set HEIGHT=”256″ for a movie 240 pixels high:For a sound-only movie, use a height of 16 for the controller and any width that looks good on your Web page. (If you set the width to 16 for a sound-only movie, the controller is minimized to a single Play/Pause button.)
For example:Never set HEIGHT or WIDTH to less than 2, even if the movie is hidden.
Miodrag Ristic
November 29, 2006 at 12:45 pmHi Chris,
As movie is going to be viewed mostly on Windows machines, you should export it as
a WMV file – not many PC users have an QT installed.
I think Squeeze should do it, I’m using Flip4Mac.With Flip4Mac is easy, just export from FCP as Windows Media Video (WMV),
keep it small (320 x 240, mono, 15 fps).Open you mail, attach your movie, you should be able to see it and play it
straight in your mail application, as well as your friends.I’m using this method to send proofs to my clients sometimes.
Don’t be confused that your movie still has a QT looking icon,
there is an.wmv extension that is telling you what file you’ve got.
Quick Time is anyway just a wrap (inside can be various codecs, Sorenson, H.264 etc.)Cheers
Mick
13
November 29, 2006 at 6:12 pmI personaly disagre that Windows Media is the most universal.
Flash is by far the most universal.
David Roth weiss
November 29, 2006 at 8:11 pm[zrb123] “Flash is by far the most universal.”
Macromedia has certainly been touting that, however, the reality is that Flash 8, the only really good version of Flash for encoding video, is not universal by a long shot. Lots of people in this world still have older Flash players installed on their computers that cannot play Flash 8, and so anyone trying to make a go of using Flash as their number one web video format for sending out their work will be very disapointed when to find out that their work isn’t being seen by a lot of people they are targeting.
I happen to like Flash 8 a lot. Its a great looking codec that creates very managable file sizes, but, that doesn’t make up for the problems I’ve encountered when trying to get unsophisticated people to actually watch Flash 8 encoded video on their computers. At the first L.A. Flash users group meeting I attended, one of Macromedia’s top evangelists even showed off some code that he said could be embedded into Flash video, that would prompt users for a really fast automatic Flash Player 8 update. It sounded great. Unfortunately it wasn’t. Not one person I tested it on could actully get it to work.
I think WM9 is still the most reliable and most universal web video format.
DRW
13
November 29, 2006 at 9:09 pmGood point about the version of flash that people might have however people could say the same thing about other formats windows media and quicktime.
I think it is fair to say that there is no one universal file type. what works for one may not work for another, there are just to many factors involved.
You cant squash every ant with one footstep, so just get as many as you can.
