OT: HD Failure, could use some help..
Posted by Terry Esslinger on February 12, 2006 at 4:40 amMy external Maxtor 200GB drive has apparently failed. It just makes some really not so great scraping and bumping sounds and I get a message that “Delayed write has failed” and that data has been lost.It just keeps searching. This was my capture drive. No OS. But it does have a LOT of graphics, pictures and especially music that I kept on it for video production. Am I just SOL or is there something that I can do. Its worth some work to try to recover but not a lot of money.Any help would be appreciated.\I have tried different cables (both firewire and USB) unloading and reloading the drivers and sftware for the drive. Letting the drive sit off for several hours (cool off) all to no avail. It would seem to be a hardware problem????
Terry Esslinger
Ken Mitchell replied 20 years, 7 months ago 7 Members · 9 Replies -
Gary Kleiner
February 12, 2006 at 7:17 amYou shouldn’t expect to see those files again unless you go for a high-cost solution of sending it off to a company that specializes in data recovery.
Try putting the drive in the freezer for a few hours. Then, if it does spin up, start copying files like crazy.
Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Allen Zagel
February 12, 2006 at 12:35 pmI have 2 Maxtor Personal storage 200Gb external HD’s here. I also get that “delayed write faiulure” message once in a while, but I don’t get any noise from the drives. Usually I just pull the firewire plug and re-insert it and the message goes away. The 2 drives are daisy-chained together.
I’m thinking one of the 1394 cables may be going bad. If that don’t work I just re-boot the computer.
In your case with all that noise, I think Gary’s right.
I just use these for storage and don’t capture to them. I’ve lost tons of video before using an external drive for a working drive, especially with these Maxtor’s. My capture drive is internal.
Only time I use an external drive for a working (capture) drive is with my laptop and I’ve never had any problems there.
AllenMy web site features;
China, China Railways and music.
https://www.azagel.comVideo site;
https://www.asxvideo.com
NEW! Shanghai MagLev DVD. -
Mike Kujbida
February 12, 2006 at 12:41 pmI’ve heard very good things about a program called SpinRite.
It’s $90 though so the choice is yours. -
Arthur Bueno
February 12, 2006 at 1:36 pmI experienced the same thing with a Maxtor 200 Gb external firewire drive recently. Got the “Delayed write has failed” message often when I switched on the DVcamera (also on a firewire bus), that seemed to confuse XP. It often recovered, but finally it didn’t and the bootsector and first MFT’s got damaged.
I ended up reformatting the drive and it works well again now, but I don’t hot-switch camera’s anymore and switch off the drive only after XP has shut down.
Or try a program called ‘getdataback’, Spinrite also seems to help, but it works from DOS, so you’ll need DOS firewire drivers.
You could also try freezing and immediately copy the files you can access to another drive, if freezing doesn’t help and the disk doesn’t appear to spin, drop the disk on a table from about 5 cm height and try again.
good luck -
Allen Zagel
February 12, 2006 at 1:40 pmBetter Chrck Spinrite. I purchased it when I had Windows 2000 and I found out that it don’t work with NTFS formatted HD’s. Only FAT. They may hae changed the program but ask before purchasing.
Allen Zagel
February 12, 2006 at 1:46 pmGuess I should have checked before “mouthing off”! HA HA I see where the ‘new’ Spinrite 6 does work with NTFS now. It is a great program and I highly recommend it. I’m glad they now support NTFS formatted drives.
Steve Gibson’s site has been at the top of my favorites list for years.
Soprry again
Chris Young
February 12, 2006 at 3:45 pmI had a similar problem some time back when moving a l75GB of material from one unit to another using an external drive. Thought I had lost the lot. Someone suggested trying ‘EasyRecovery Professional’ from Ontrack Data Recovery.
https://www.ontrack.com/easyrecoveryprofessional/
To cut to the chase it took around two and a half hours to interrogate the faulty drive and another couple of hours to recover the data, just make sure you have sufficient space on another drive system for the recovery. To my utter amazement it recovered 100% of all the data files, video, pics the lot in their respective folders, and more to my amazement it created a new folder called ‘lost files’ and when I looked into that I found files that had been deleted in the previous ten days or so.
To say I was blown away by the success of the recovery was an understatement. Seeing as now I had now recovered all missing files I thought I would give the drive another go as a test. Did a full re-format and ran the drive on non mission critical files and it hasn’t missed a beat in the last eight to ten months or so since the recovery session. Since then I have used the software a couple of more times for others who had drives that wouldn’t mount and in each case got all their data back. If the drive won’t run then this won’t help but if it does it might be worth a go. The deep freeze trick, overnight, is well known and sometimes will give you enough time to recover your data before it heats up too much.Chris Young
CYV Productions
Sydney -
Chris Young
February 12, 2006 at 4:00 pmI forgot to add EasyRecovery Pro is not cheap, the Standard edition lists for $499. There is a Lite version which will recover 25 files per session which lists for $89 so I guess it depends on what the data is worth and how much time you have to recover it.
Chris Young
Sydney -
Ken Mitchell
February 14, 2006 at 4:23 pmI have been using ONTRACK DATA RECOVERY standard edition for about 2 years. Works great if the drive will spin. Made me a hero many times. Will not work with serial drives hooked up to your computer..
