Activity › Forums › AJA Video Systems › OT: First HD Shoot & Edit
Posted by Dave Jenkins on January 19, 2006 at 5:32 amWe are doing our first HD shoot and edit and the DP want to shoot 24P. Is there anything I will gain or lose by shooting 24P instead of 60i ? We will edit with FCP 5 and a Kona LH. The final edit will go to SD DVD and the web with storing the project for future use for HD DVD when it get here. We will edit in the DVCPRO HD 1080i codec.
Thanks for your input.
Dajen Productions
Santa Barbara, CA
G5 Dual 2 Gig – AJA IO & LA
Huge 1.2 Raid
FCP 5-OS X 10.4.1-QT 7Dave Jenkins replied 20 years, 8 months ago 3 Members · 9 Replies -
Walter Biscardi
January 19, 2006 at 12:25 pm[Dave] “Is there anything I will gain or lose by shooting 24P instead of 60i”
24p gives you a “film type look” which with some cameras will soften the image a bit. 60i gives you the look of “live tv” and produces a very very sharp image.
With 24p you need to be very careful with camera movements, especially pans and tilts. With 60i your movements aren’t really restricted at all.
Best advice is do some testing with the camera. Shoot one way, edit a bit, shoot the other way, edit a bit and go with whatever works the best for you and the project.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Dave Jenkins
January 19, 2006 at 1:27 pmThanks, Can I mix 24P & 60i in Final Cut? I was planning to use the pull down on the 24P and edit in 60i.
Dajen Productions
Santa Barbara, CA
Huge 1.2 Raid
FCP 5-OS X 10.4.1-QT 7 -
Walter Biscardi
January 19, 2006 at 1:43 pmWith DVCPro HD I do this all the time. We always capture in 59.94 and just edit in the 59.94 timeline, especially for broadcast work.
Walter Biscardi
January 19, 2006 at 1:43 pm[walter biscardi] “With DVCPro HD I do this all the time. We always capture in 59.94 and just edit in the 59.94 timeline, especially for broadcast work.”
but just to clarify, we edit in progressive, not interlaced. we convert to 1080i after mastering.
Dave Jenkins
January 20, 2006 at 6:39 amThanks for the info Walter
Dajen Productions
Santa Barbara, CA
Huge 1.2 Raid
Dave Jenkins
January 22, 2006 at 6:54 pmOkay we bought the Kona LH, we are shooting with the Sony 900’s at 24P.
Should I let the Sony JH3 HD Deck do the convert to 1080i @ 29.97 or 59.94.
Should I edit in 24P or should I let the Kona LH convert to 1080i @ 29.97 or 59.94.
Does it make any difference if we shoot in drop or non-drop frame?Thanks Dave
Dajen Productions
Santa Barbara, CA
Huge 1.2 Raid
Walter Biscardi
January 22, 2006 at 7:17 pmI havne’t done any work ingesting and editing with HDCAM for about two years so I’m not really a great person to give you any advice on that.
Basically you should do a few tests on several workflows and see what works the best for you. We spent about 6 months working out the post workflow for Good Eats and now it’s a pretty straightforward workflow.
Gary Adcock
January 23, 2006 at 5:47 pm[Dave] “Okay we bought the Kona LH, we are shooting with the Sony 900’s at 24P.
Does it make any difference if we shoot in drop or non-drop frame?”I would digitize the footage into FCP as 1080 24 using DVCPROHD then you have your master in HD.
The just downconvert only when you need to, from the Kona card. That way you will get the most out of the HDcam footage and the Kona card.Gary Adcock
Studio37
HD and Film Consultation
Chicago, IL USA -
Dave Jenkins
January 24, 2006 at 3:56 amThanks Gary, I’ll try that. We are finishing on DVD and web. Does this make any difference?
Dajen Productions
Santa Barbara, CA
Huge 1.2 Raid
