Activity › Forums › Apple Final Cut Pro Legacy › OT: Experiences with PVM-L5
Posted by Sven Hanten on September 14, 2005 at 11:25 amHi,
I need a CRT multiformat monitor and the cheapest Sony I found was the PVM-L5.
What experiences do you have with this model?
What about the formats? As I understand it is only PAL, NTSC, 720p60, 1080i50, 1080i60. No 1080p24 or 720p24? Is this correct?
Any other comments about quality, etc.?
Thanks in advance.
Kind regards
SvenWalter Biscardi replied 21 years ago 5 Members · 7 Replies -
Walter Biscardi
September 14, 2005 at 11:46 amI have the 20″ model which is getting very hard to find now, but if you can find it it’s outstanding. I cut both HD and SD with full color correction on the monitor and it’s colors are very true.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Now editing “Good Eats” in HD for the Food Network
Mitchji
September 14, 2005 at 4:38 pmHi,
If you can find a PVM-14L2 or PVM-20L2 it will be cheaper. It will use P22 phospours instead of SMPTE-C. Both phospours have identical color so that is not an issue. The L2 series have lower resolution. 600 lines vs 800. For DV which has 500 lines that is not an issue. We just got a PVM-14L2 for $850 from B and H. Sony had used it at a tradeshow, hence the discount.
Best Wishes,
Mitch
Misha Aranyshev
September 14, 2005 at 4:54 pmI believe the original L5 doesn’t have 24p support but revisions -like 20L5/1 or 20L5/2 do.
Walter Biscardi
September 14, 2005 at 5:01 pm[MitchJi] “If you can find a PVM-14L2 or PVM-20L2”
the L2 does not have support for progressive like the L5/1’s do so I would stay away from the L2 series if you plan on working with HD.
A.lee
September 14, 2005 at 5:06 pmI have the pvm l5, from bh, I got a good deal and similar story that someone else mentioned about a trade show use. had it a few years now and it has been perfect.
Sven Hanten
September 15, 2005 at 1:11 amThank you a lot for sharing your experiences with me.
Yes, I want to view SD and HD content on it.
And I need a monitor that can also display 1080/24p or 1080/48psF. So can the PVM-L5 or not?It is interesting that there are also different Versions available. I don’t know that before.
Regards,
Sven -
Walter Biscardi
September 15, 2005 at 1:43 am[Sven] “And I need a monitor that can also display 1080/24p or 1080/48psF. So can the PVM-L5 or not?”
The PVM-L5/1 and L5/2 monitors can display progressive just fine. The straight L5 cannot. They’re getting very hard to find as Sony is no longer making them so if you find one, buy it.
